Suspension Lift vs. Leveling Kit
Old Feb 9, 2010 | 02:03 PM
Collie's09's Avatar
Collie's09
Default Suspension Lift vs. Leveling Kit
With the current problems occuring due to leveling kits what is the safest way to go, suspenion lifts or leveling kits?
I want to do the Mopar 4inch suspension kit and run 35's with 3:55 gears and I don't want to run into unforseen problems down the road on my daily driver so if yall could give me some insight I would def appreciate it.
Thanks!
Old Feb 9, 2010 | 02:20 PM
StuartV's Avatar
StuartV
I raised mine using Bilstein 5100 leveling shocks all around, and 1.5" spacers just in the back. My 4x4 was smooth before and now I have The Shudders. I'm not sure about the official terminology, but I would call my a suspension lift. So I don't think suspension versus leveling kit makes a difference to whether you'll have problems or not.
But, if you go with a Mopar kit and have it installed by a Dodge dealer, you should at least have no trouble with getting stuff fixed under warranty.
Old Feb 9, 2010 | 02:26 PM
Collie's09's Avatar
Collie's09
K, thanks. Does yours just shudder in 4 wheel drive or all the time?
Old Feb 9, 2010 | 03:58 PM
TI 3VOM's Avatar
TI 3VOM
MIne has the 2.5 leveling kit from Dodge that raised the back 1 inch as well. Not sure how raising the front and back is considered a leveling kit and not a lift, but it is a leveling kit....
Mine has no issues what so ever. No shudders or anything. It was installed by Dodge though, so if issues arrive, it is up to them.
Old Feb 9, 2010 | 05:18 PM
jake09's Avatar
jake09
A suspension lift should be a lot better...it's not the same as a leveling kit..by using a leveling kit you still have the stock struts, control arms etc and the kit just strains your joints...but a suspension lift changing everything which puts your geometry back on line and not at extreme angles that could wear fast...i have a leveling kit and it does shimmy some also
Old Feb 9, 2010 | 09:33 PM
cwoposey's Avatar
cwoposey
I have the Rough Country 2.5 front/ 3/4 rear level kit and I have no issues for 7000 miles, not even at 100 MPH, carrying a heavy load on bumps.
Old Feb 9, 2010 | 09:55 PM
bkc's Avatar
bkc
Default go body lift
put a 3 inch body lift on it and you wont have any of those problems.
Old Feb 10, 2010 | 09:54 AM
StuartV's Avatar
StuartV
It's bad in 4WD. At first, I thought it was completely smooth in 2WD, but I've been starting to notice a slight vibration, and I'm suspicious that it's because of the lift. My tires only have 6,000 miles on them and I had them rotated and balanced in the last 2,000 miles, right about when I got the lift done and the truck aligned.
I'm thinking about taking my rear spacers out and lowering the front shock setting from the very top all the way down to the lowest setting. That *should* put the truck back to stock height. Then see how it is and, maybe, take it to the dealer.
Old Feb 10, 2010 | 10:24 AM
Collie's09's Avatar
Collie's09
Thats what I was wanting to hear. Thanks for the info.
Old Feb 10, 2010 | 10:52 AM
Ryan Albert's Avatar
Ryan Albert
If you have no problem dropping the cash on a suspension lift you might as well go that way. I have a rough country leveling kit, and 10k later have had no issues. I would of loved a suspension lift, but didn't want to spend 2k+ for one. With the leveling kit on, I would definitely not describe my angles as extreme.
