pace-edwards fullmetal_jr
Old Feb 15, 2010 | 06:09 PM
bvigne01's Avatar
bvigne01
Default pace-edwards fullmetal_jr
I just got a Pace Edwards Full Metal Jack Rabbit with the Explorer rails. I’m not that impresses with the fit for the 2009 Dodge. The Canister doesn’t fit down on top of the rear bed wall there is about a half inch gap from the lip of the canister to the top of the bed. They provide some cheep stick on seals that are not big enough to fill the Gap. There is a half inch gap in each corner of the tailgate where the seal don’t cover. I have only had it 2 days but don’t think it’s going to be water resistant. It will be better then nothing but not as good as a vinyl cover
Old Feb 16, 2010 | 04:47 PM
Cruzin90's Avatar
Cruzin90
For about the same price, TruckCoversUSA is a better cover. The slats are double-walled aluminum and inter-lock with each other. The PE FMJ is not double-walled and the slats are linked with rubber. The only possible "con" with the TCUSA is that there are 4 drain tubes, not 2. So, holes must be drilled into the stake pocket columns at the rear of the bed. It's not that big of a deal, but some people might not like that.
