Towing a boat with a 4th Gen
Old Feb 16, 2010 | 06:52 AM
zx14k's Avatar
zx14k
i tow a 27 feets baja(about7000 lbs and 500 lbs on the thong) with a 09 hemi 4x4 3.55 it is just like i have nothing on the back.
Old Feb 16, 2010 | 07:22 AM
Islander_212's Avatar
Islander_212
Originally Posted by Korgae
How does the truck do with the towing part? I have a 5.4 F150 right now but am about a week away from getting a new 4x4 1500 Ram sport with the 5.7 and the 3.93 rear end.
I love the truck on the test drive but of course they wont let you test drive it with the boat behind LOL.
My boat weights about 6500 lbs
Thanks in advance
Towed a 27' Baja from Louisville to Chicago last year to the Loop Cruise that was about 6,000 lbs with the bed of the truck completely full and it did great. I got about 14 MPG with the tow running right at the posted speed limit the whole trip.
My 5,000 lb. boat was towed to Lake Norris twice last year with each trip around 120 miles one way and did fine with fuel mileage a little less due to the much more hilly terrain than the Chicago trip. Our other 24 weekends are all much shorter. It is only one mile to our home ramp from the boat storage and only 20 minutes or so to our other "hot" spots.
I will be towing the 27' again this year from Louisville to Wabasha, MN for the Liquid Jungle Poker Run in August. That is about a 10 hour haul. I will report back after that little pull. I also now have a 39' camper that will likely be around 7500 lbs. that I will put on short trips this year too that I will let everyone know about too.
In all conditions I hardly noticed the boat(s) back there. Even up the hills in Southern KY and Northern TN it easily maintains the 70 speeds on the interstates when others are slowing down. I assure you the power is not a problem regardless of the load.
Old Feb 16, 2010 | 09:14 AM
rolltidehemi's Avatar
rolltidehemi
Originally Posted by JLK
So I'm a relatively new owner of a 2009 Sport 2WD Hemi with 3.92's. I have searched and read every thread on these forums regarding towing, so please dispense with the "Search is your friend" flames. I own a Checkmate ZT280 28' offshore style boat weighing in at 6800 with trailer and a full load. I know I'm within towing capacity. I know it will pull it without much trouble. I have already done it. My question for anyone with any insight is whether or not the 2WD is gonna be an issue getting the boat up a fairly inclined loading ramp on those wet sloppy afternoons. I have a 10000lb Equalizer hitch setup with anti-sway and leveling. Now that I got the thing all set up, it has less than 1/4 of an inch squat and you don't even know its there, even at highway speeds. I figure if lack of weight over the rear axle causing slippage is an issue, I can just pop the weight distribution bars on the equalizer off and set all 700lbs of tongue weight right on the rear end. Should I be worried about the 2WD not havingthe grip to get a big boat up the ramp? Anyone towing a bigo boat with a 2WD? Any input would be great.
I use to pull around the same wt. with my 04 2wd hemi no problems except at low tide when the angle of the ramp changed and the trailer tires got on to this part due to the low tide, then I would need a person bouncing on the rear and a moving start, the ramp also had cuts in the concrete for traction, they make a bladder bag that you can put in the back of the truck bed and fill with water when you need it. but now have a 4wd and no worries where I go, and tows better than my 04, the 04 was really good too.
