Pics of my lights
Old Feb 21, 2010 | 09:53 PM
oyen24's Avatar
oyen24
Default Pics of my lights
Old Feb 21, 2010 | 10:00 PM
jason2922's Avatar
jason2922
Very nice, can you post a informative thread with parts and wires/colors/info needed if others wanted to do the same?
Would be complete if you had some 6/8K HIDs
Old Feb 22, 2010 | 04:08 PM
briansg's Avatar
briansg
WOW! i saw your other post and i and it sounded like a good idea then, but it turned out better than i thought
i would like to see the install
Old Feb 22, 2010 | 07:24 PM
oyen24's Avatar
oyen24
Thanks guys, I am just glad it worked out the way I wanted it to. I am going to try and get some 6k hids, but it might be a little bit before that happens. As for the informative thread on how I did this, I will try to post something asap, otherwise if someone is interested just pm me and I will help you out.
Old Feb 23, 2010 | 08:20 PM
oyen24's Avatar
oyen24
Here is a quick over view of how I did my lights. I bought a set of white underbody lights from Ledglow. Followed there instructions for how to mount them, then ran all the wiring to the drivers side of my truck. Put the wires up through the area where my ebrake cable comes through the floor board of the truck. I did tape all the wires to make sure that there is no damage done to the light wires. I then ran a 14 guage wire from the battery to inside the cab through the fire wall. I also ran a 14 guage wire from inside my door panel into the cab following the existing wires that run from the cab to the door. I took a test light to find the wire that feeds my mirror light. I think the color is something and brown. You will be able to find it useing a test light. i also wired in a relay switch because bullram said it would be a good idea. I found the wiring diagram of a relay switch online and followed those instructions. After I got the relay wired, I took the light wires and plugged them into the 4 wire plug in. The wire that runs from the 4 wire plug in to the led lights control box is the wire that I cut. I stripped back the insulation cover and exposed all the wires. I found the wires that are the power wires ( 3 of them) and twisted them together and hooked them to the relay. The rest I twisted together and hooked them to the ground. After that, it is pretty much hiding your wires and makeing sure everything works. If anyone has any questions just let me know.
Old Feb 24, 2010 | 06:44 AM
BULLRAM's Avatar
BULLRAM
I am glad it worked out for you, it looks great, if you need anything else PM me,
