What Temp does your Oil run at?
Old Mar 4, 2010 | 02:08 PM
Ballfroguy's Avatar
Ballfroguy
Default What Temp does your Oil run at?
I have Mobil 1 Extended Synthetic and the expensive Mobil1 Oil Filter. When I first got it, it was pretty cold outside so it ran low. Now today its about 65F here in Austin, TX and I noticed it was at 204F. Is that normal? I know there are those bars in the middle and it was bearly past it but I just want to know what temps yall run at too. Also wheather conditions might help too. Thanks guys!
Old Mar 4, 2010 | 02:31 PM
SubRammer's Avatar
SubRammer
That's absolutely normal. I'm from Florida and during the summer with temps near 100 I've seen oil temps approaching 215-220 while in traffic. You have nothing to worry about, these are iron blocks and tolerate heat much better than those fancy aluminum blocks.
Old Mar 4, 2010 | 03:12 PM
Ballfroguy's Avatar
Ballfroguy
Awesome. Ya I was kind of worried but if you say its cool Im cool. Thanks.
Old Mar 4, 2010 | 03:20 PM
Dr. Bill's Avatar
Dr. Bill
You will normally see the oil temps sitting a few degree higher than the water temp. You want the oil to get over 200 degree so that any water in the oil will burn off as a vapor.
