Hertz component speakers - Installed
Old Mar 25, 2010 | 01:58 AM
laboy's Avatar
laboy
Good idea for front speaker. (I heard better to disconnect it). Where did you hide crossovers?
Thanks!
Old Mar 25, 2010 | 06:04 PM
Doc Fluty's Avatar
Doc Fluty
the front door speakers on receive low freq only. so youll need to use the dash side speakers to get the full range sounds
cross was in the doors im pretty sure
Old Mar 25, 2010 | 09:01 PM
72combo's Avatar
72combo
Originally Posted by Doc Fluty
to hook up speakers you need to unplug a fuse and remove a battery cable?
hell i hook up speakers with music playing half the time to make sure their working lol
Here is the link to the TSB for removing the fuse before removing the radio.http://www.wkjeeps.com/tsb/tsb_wk_0800309.pdf
Doc check out that site it has the instructions for taking our console apart, you willl see the screw that is supposed to be removed behind the little bezel that is around the 120V plug...but like you said it is not loose for you so..
