A/C controls problems
Old Mar 20, 2010 | 07:36 PM
Sniper308's Avatar
Sniper308
Default A/C controls problems
Just installed my subs in my 09 Ram, and now the A/C controls don't work. The fan turns on and is adjustable but there is no lights and can not change blower position. I think this was recently a recall I had done, but worked fine until I put the module in for RCA's to stock radio non gps. Should I take it back to dodge or is there something I'm missing? All plugs seem to be plugged in and secure in the right spots. Help summer coming.
jason
Old Mar 20, 2010 | 11:00 PM
plumcrazy73's Avatar
plumcrazy73
if they worked prior to you doing the sub work, it is from something from that. something that came unplugged or not plugged in fully. loose connection is my guess
or something one of the components used for the adding of the amps is causeing problems, just my guesses could be wrong
Old Mar 23, 2010 | 03:34 PM
Sniper308's Avatar
Sniper308
Was using a PAC-1 no splice for use with RCA's. I took it out and everything works fine now. This sucks Anyone else had this issue with the PAC-1?
