Oil Light and Stall Out After Neutral Engine Rev....
Old Mar 22, 2010 | 12:28 AM
RamPhreak's Avatar
RamPhreak
Default Oil Light and Stall Out After Neutral Engine Rev....
So I was in front of my house and reved the engine while in neutral pretty aggresively but only one pedal blip. "DING", stall, oil light......the truck felt like it wanted to move a bit too. I have not yet done the RRT for the "lurch,clunk" issue I have seen previously.
Anyone else have this issue before? I restarted it no problems right after that. It was weird but not a huge concern. I will however call my service rep to inquire about it.
Old Mar 22, 2010 | 04:47 AM
Doc Fluty's Avatar
Doc Fluty
mine died on me at a stop light one time. I shifted in nut. to show off the borla to the wifey.. it just died.. started right back up and no probs since.. that was prolly 6-8 months ago
Old Mar 22, 2010 | 12:37 PM
j0e's Avatar
j0e
mine did it once, almost a year ago, back when i first got it.
never happened again since then.
Old Mar 22, 2010 | 06:25 PM
rolltidehemi's Avatar
rolltidehemi
they do have a protection in them from being over reved over certain rpm in neutral/park.
Old Mar 22, 2010 | 08:50 PM
navyr6's Avatar
navyr6
yep, had the same thing happen to me once
Old Mar 22, 2010 | 09:24 PM
RamPhreak's Avatar
RamPhreak
Thanks for confirming guys that these trucks are retarded... At least I am not alone.
I will see what else I can find out about it. As far as a rev limiter...most computers cut out...not off. It also doesn't expalin the oil pressure light coming on. Seems to me that this is a potential safety issue with some of what you might be saying..... I will call Mr. Toyoda to find out what we should do.
Old Mar 23, 2010 | 12:48 AM
cpelton's Avatar
cpelton
they have protection for lack of oil pressure which kills the engine, as well as a rev limiter which cuts fuel. I dont know what would cause the lack of oil pressure while revving maybe it compares pressure to RPM and when the rpm climbs fast with no load it kills the engine before the oil pressure can react?
Old Sep 1, 2010 | 02:02 AM
chedachris's Avatar
chedachris
Any update on this? My truck continues to have this problem and I don't rev it.
Old Oct 4, 2010 | 08:57 PM
newram2010's Avatar
newram2010
has anyone figured anything out about this??
I had mine stall a couple months ago and never thought much of it, but i got er stuck in a mud hole the other night so i locked it in 4 low, and everytime i made a run for high ground and got stopped in the mud it would stall after i took my foot off the gas and it idled down. it did it probly about half dozen times till i started leaving throttle to it and slowing it down by slowly lettin off the gas.. the dealer in town here is HORRIBLE so Id be cruising down south about 8 hour drive to have it serviced if this is a big deal what do you think??
Old Oct 4, 2010 | 09:02 PM
newram2010's Avatar
newram2010
sorry... when it happened a couple months ago i was in neutral... but when it was happening the other night i was in 4 low Drive, and 4 low Reverse...
