help me pick tires. (something close to 285/65/20)
Old Mar 22, 2010 | 09:14 PM
crod's Avatar
crod
Default help me pick tires. (something close to 285/65/20)
ok, it seems that 285/65/20 is the biggest that will fit stock rims, truck. (roughly 34.5" x 11.22)
so far i have only found, bfg all terrains, goodyear wrangler mt/r kevlar...
im on the fence. i would like some more choices, but its hard finding a tall "skinny" tire. most of em are in the 12" range....
Old Apr 4, 2010 | 11:38 PM
MTtruckr's Avatar
MTtruckr
It seems people are getting 35 x 12.50 tires on their 09's with a leveling kit. I am really thinking about Mickey thompson atz's in that size; they measure at 34.5.
Old Apr 5, 2010 | 07:36 AM
Frouburg's Avatar
Frouburg
I take it if you put on 35"x12.50's, you are also getting new rims with a higher backspacing?
I am looking at putting on a 3" lift, but want to keep my 20" chrome clads for the time being. Anyone know what the largest size tire is I can fit without much rubbing?
Old Apr 5, 2010 | 08:54 AM
010 Sport's Avatar
010 Sport
I too am wanting to do 35/12.50-20's on the factory wheels....but seems like some mixed answers on whether they fit or not. I can deal with or take care of some fender rubbing....but not much one can do about a-arm rubbing tho, which is where I've had trouble finding a straight answer in my searches.
So that being said.....subscribed!
Old Apr 5, 2010 | 10:15 AM
MTtruckr's Avatar
MTtruckr
I am slightly skeptical too, but I've talked to some people that have 35 x 12.5 trail grapplers with 2.5 leveling kit in the front and 1 inch rear. Stock 20 rims from a sport. From the pictures they looked like they actually had good clearance. It's enough to make a guy think about it.
Old Apr 5, 2010 | 01:58 PM
BOWERSFJ's Avatar
BOWERSFJ
Bridgestone Dueler Revos
Old Apr 5, 2010 | 06:28 PM
010 Sport's Avatar
010 Sport
I'm sorry to hijack ....but where did you find pics of this setup?! I wanna see!!
And just so its not totally off topic of the original poster...I've personally had good luck with the bfg a/t's and the nitto terra grapplers. Tho I have heard some terrible stories about the terra grappler, I had good luck with two different sets.!
Old Apr 5, 2010 | 06:33 PM
cwoposey's Avatar
cwoposey
I have the 285/65-20 Goodyear MT/R's. I also have the 2.5/1 Rough country level kit. The MT/R's look great and they do not rub. However, the snow and wet traction is not great and they howl like a coyote in heat. I previously had the BFG's and when the MT/R's wear out I am going back.
Old Apr 5, 2010 | 06:46 PM
crod's Avatar
crod
well, if you look, the only people that are fitting 35"s on stock's are guys with lift kits. most people are going aftrmarket rims with a little diff. backspacing to fit em on a level'd truck.
the rims are actually a little too narrow at 9" for 35x12.50's even though some people run them.
Old Apr 5, 2010 | 06:53 PM
010 Sport's Avatar
010 Sport
I've run wider tires on an 8.5 so that part is really of no concern to me personally, but whether the tire will rub the a-arm or some suspension comonent is of vast concern to me! Which, is the part that I cant quite find an answer to. As I said....I can handle/take care of a lil feder rubbing but struggling to find a "component rubbing" answer anywhere.
