exhaust
was at the dealer today. Saw a 1500 5.7 4x4 off road package with single exhaust. The other 1500 hemi's had dual exhaust. Salesman didn't know why one had single and others had dual. Does any one here know. I like the duals but really like the off-road 1500.
tks
tks
What ever you do...plz wait for someone in here with one like you want that can give some good advice before you purchase. There are so many different in the options in these trucks...some that hide the best values for your typical needs...good luck!
Part of the SLT decor plus package.
I am sure it is in some of the others as well.....
includes many things and this....
1,695 dollar package....
Try a new salesman, if he doesn't know the difference, he doesn't know the features....
Feature: Quasi-dual exhaust system
An exhaust system that has one exhaust pipe immediately from the engine, then splits near the rear of the vehicle to give the appearance of a true dual exhaust.
Wheels: 20" x 8" Aluminum
Centre Hub
Full Size Restricted Use Spare Tire
Locking Lug Nuts
Tires: P275/60R20 BSW AS
Body Colour/Chrome Door Handles
Bright/Bright Billets Grille
Dual Rear Exhaust (NER)
Fog Lamps
Halogen Quad Headlamps
Luxury Group
Ash Tray Lamp
Auto Dim Exterior Mirrors
Exterior Mirrors w/Supplemental Signals
Exterior Mirrors Courtesy Lamps
Glove Box Lamp
Leather Wrapped Steering Wheel
Steering Wheel Mounted Audio Controls
Overhead Console w/UGDO
Power Heated Fold-Away Mirrors
Rear Dome w/On/Off Switch Lamp
Rear View Auto Dim Mirror
Sun Visors w/Illuminated Vanity Mirrors
Underhood Lamp
Universal Garage Door Opener
This option features:
Feature: Front Curb Weight
The curb weight that is supported by the front wheels when the vehicle is at rest.
Feature: Chrome grille
The decorative appearance of the opening on the front of the vehicle. Designed to protect the radiator from large debris and to assist in channeling air to the engine compartment.
Feature: Chrome door handles
The exterior door handles are chrome.
Feature: Multiple enclosed headlamps
The headlamp system contains separate bulbs for the high and low beams. Both are located in the same housing behind a shatter-resistant transparent cover.
Feature: Front fog/driving lights
Auxiliary front fog or driving lamps extend the lighting range beyond the capabilities of many standard headlamp systems.
Feature: Front Wheel Diameter
The diameter of the wheel rim, not including the flange or lip of the rim.
Feature: Front Wheel Width
The width of the front wheel rim, not including the flange or lip of the rim.
Feature: Rear Wheel Diameter
The diameter of the rear wheel rim, not including the flange or lip of the rim.
Feature: Rear Wheel Width
The width of the rear wheel rim, not including the flange or lip of the rim.
Feature: Silver colored wheels
The front and rear wheels are silver in color.
Feature: Alloy wheels
Alloy wheels are light and strong.
Feature: Curb Weight
The weight of the vehicle including standard equipment and all fluids. It does not include passengers, cargo or optional equipment.
Feature: Rear Curb Weight
The curb weight that is supported by the rear wheels when the vehicle is at rest.
Feature: Front tire/wheel capacity
The maximum safe load capacity of the tire and wheel combination used on the front axle of the vehicle.
Feature: Rear tire/wheel capacity
The maximum safe load capacity of the tire and wheel combination on the rear axle(s) of the vehicle.
Centre Hub
Locking Lug Nuts
Fog Lamps
Luxury Group
Ash Tray Lamp
Glove Box Lamp
Underhood Lamp
