Updated 0-60 times
Old Mar 27, 2010 | 08:52 PM
CarGuyOhio's Avatar
CarGuyOhio
Default Updated 0-60 times
It has been about a week since putting on the last piece, that being the K&N CAI. Which means the only performance adders is Superchips (93 tune), K&N CAI and Mufflex 14.
On Monday night 5.9 was the best I could do. Was rushed as it was not ideal conditions, cars coming up behind me from a distance so I could not take the time to stage and prepare.
Tonight.... About the same weather conditions. Just under 1/2 tank of gas vs the full on Monday. Also went way out to no mans land, but a very good road surface.
3 launches, all with ESP partially off.
2nd, was the worst of all three. 5.89. Launch was a simple release brake and apply gas from idle. Traction issues doing this. But if I would not have feathered it out the coolness factor would have been high.
3rd, second best. Launch was with brake appied and RPMs around 2K, release brake and mash the gas. 5.83.
1st, best run. Same launch as my 3rd run, but the results better at 5.72.
Keep in mind I am a RCSB Hemi Sport 4x4 with 3.92s. I guess the next logical step would be the torque converter, but I am in save mode now. Time to build a new house.
I would also like to add, the K&N CAI appears to have dropped my MPGs. I will only say appear for now though. Give me 3 more weeks to give a better accessment as I want to run a "normal" tank.
Old Mar 27, 2010 | 09:52 PM
jayman84's Avatar
jayman84
pretty nice for a 4x4 truck! will the flashpaq do more times other than the 4 in the picture. example, will it measure 0 to 80 times or 0 to 100 times?
Old Mar 27, 2010 | 09:58 PM
CarGuyOhio's Avatar
CarGuyOhio
I do not recall, would have to look. It will measure distance as well, 60 ft up to 1/4. Of course accuracy of those are up in the air. I think the speed logs are damn close if not right on. Being it is hooked to the PCM it knows when you start rolling and when you hit 60MPH.
Old Mar 28, 2010 | 07:23 AM
CarterT1975's Avatar
CarterT1975
Very impressive.
