Old Aug 14, 2015, 06:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
What's squeaking?
Old Apr 12, 2010 | 09:47 PM
neenahhemi's Avatar
neenahhemi
I have the same squeaks you are talking about. I also have the rough country leveling kit. If I go underneath the back of the truck, and push up I can hear the squeaks. On my truck it is coming from the shocks, and the stabilizer bushings. I have tried lubing with wd40, and it helps somewhat, but it still is squeaking. I also can hear the same noise in the front. Does anyone without a leveling kit have this problem?
Old Apr 13, 2010 | 09:56 AM
jawsdc's Avatar
jawsdc
i have bags in the rear with the large spacer on top. i have not been under there to see if i can duplicate by pushing up, might need to get by the gym first.
i'm not positive, but my noise seems to be coming from the front; no modifications under there.
Old Apr 13, 2010 | 11:44 AM
24tbarker's Avatar
24tbarker
If any of you with the chirping sounds have the Rambox, check the lids.
Old Apr 14, 2010 | 08:27 PM
neenahhemi's Avatar
neenahhemi
Boy this squeaking is driving me nuts! Ive gotten the rear suspension to stop squeaking, but the front still squeaks bad. It almost sounds like it is coming from in by the rotors. I can hear it when someone pushes the front bumper up and down.
Old Apr 17, 2010 | 03:16 PM
guitarvenue's Avatar
guitarvenue
Talking
Originally Posted by Ryan Albert
Sprayed the rear spacers with WD40 and still squeaking.....
Get yourself a caulk tube of PROTHANE Bushing grease and tell me what you see.
Old Apr 17, 2010 | 03:36 PM
NatesgotaHemi's Avatar
NatesgotaHemi
wd/40 is not a lubricant....try a good silicone based spay lube. jack up truck from frame to unload the suspesion to get a good coating on parts that rub.
Old Apr 17, 2010 | 03:43 PM
guitarvenue
keyword = suspension bushing grease Prothane part number 19-1751
Old Apr 22, 2010 | 09:12 PM
Ryan Albert's Avatar
Ryan Albert
Default Found Squeaking Noise Cause
So after poking around for a little bit I found the source of the annoying squeaking. It is my front Rough Country strut spacers. Basically with their kit the spacer sits directly on top of the strut assembly and its rubs against it and since they are both metal it squeaks.
I looked up the kit I bought on Rough Country and I see now in the kit they include a rubber bushing to go in between these two parts.
I called them and inquired about this, and basically they added it later because of the squeaking noise, and the representative advised me to get a piece of rubber and cut it out and put it in between.
I am not too happy with Rough Country's answer, because since the failed to do proper research on a product before releasing it, they had to change it, and now people who have the original problematic product is screwed.
Now I have to tear my truck apart again, make my own spacer, and pay for another alignment..
Old Apr 23, 2010 | 10:00 AM
jawsdc's Avatar
jawsdc
man, i would be pissed! sorry to hear that, but i don't have any mods in the front of my truck. i'm going to ask about the bushing grease next time i'm in for service.
Old Apr 25, 2010 | 02:01 PM
lbf22bls's Avatar
lbf22bls
I found that my squeak has been coming from the driver’s front wheel well liner. I added a plastic spacer between the wheel well trim and the liner to add additional compression to minimize the squeaking. It has not completely eliminated it, however I only hear it now on extremely windy days.
