u connect volume
Old Apr 12, 2010 | 07:59 AM
qicvick's Avatar
qicvick
Default u connect volume
searched but couldn't find
I found the volume control for the Nav. voice and it is right were it needs to be, even the voice saying incoming call or phone connected is right, however when someone answers a call ( cant hardly even hear the phone ringing) you can barely hear them, I know you can turn up radio volume to hear but when you hang up the stereo will bust your eardrums, my bro in law says his has always been that way but mine just started, any ideal how to adjust the other callers volume . like I said , mine just started this?
Old Apr 12, 2010 | 03:48 PM
pdavis53's Avatar
pdavis53
Next time you are on a call just turn the volume **** that controls the radio volume. It is different then the radio volume so when you end the call it will return to the radio's volume before the call. From what I can tell you can only adjust during a call. I adjust mine all the time depending on who I am talking to and where the volume needs to be.
Old Apr 12, 2010 | 06:46 PM
72combo's Avatar
72combo
Not an issue here either, whatever the phone is set to while in a call remains that way for calls only. The radio volume.sat,and dvd whatever else is different
Old Apr 12, 2010 | 07:43 PM
qicvick's Avatar
qicvick
Mine is acting different, I had the volume turned all the way up just to hear the person on the line, the volume was a different color than the radio, when I hang up the radio is wide open! volume graft different color shows it is wide now also, when on the phone you can hardly hear the person even wide open, just started this week
Old Apr 12, 2010 | 07:51 PM
Ironhead's Avatar
Ironhead
Mine works the same as 72combo and pdavis53 described
Old Apr 12, 2010 | 09:16 PM
AndiDarko's Avatar
AndiDarko
mine as well works the same as 72combo and pdavis53 and ironhead
Old Apr 13, 2010 | 07:03 AM
qicvick's Avatar
qicvick
Mine has always worked that way before, I am also getting a clear echo of my voice when I talk, about 3 or 4 words behind what I say, like I said when I call someone I can hardly tell when they answer, turning up volume while they are on the line to wide open helps but they are still hard to hear, the graft volume is green I beleve, when I hang up the graft volume for the radio is yellow and it is now wide open,
