87 with no ethanol, or 89 with ethanol?
Old Apr 12, 2010 | 01:25 PM
jugdish's Avatar
jugdish
Default 87 with no ethanol, or 89 with ethanol?
A local gas station by me sells 87 octane with no ethanol at all in it, and then it sells 89 with the standard 10% ethanol in it. What would be the better choice? I have heard that even a little ethanol can cause problems in engines. Unfortunately it has become almost standard for 10% ethanol to be mixed in at all stations around here.
The 87 is about 10 cents more per gallon than the 89 because of the lack of ethanol.
Old Apr 12, 2010 | 01:32 PM
doraz's Avatar
doraz
it is a law in the state of PA 10% ethanol has to be in all gas. I think by now manfacturers have made their engines 100% safe for ethanol. The only things I have heard might have issues were older lawn mowers, tractors, weedwackers, etc.
I would put in 89 if you don't mind paying the extra 10 cents or so per gallon as per the owners manual.
Old Apr 12, 2010 | 01:44 PM
tombogue09's Avatar
tombogue09
As long as you don't put e85 in a hemi then it should be fine. By all means get the 89 octane, especially if its cheaper
Old Apr 12, 2010 | 01:55 PM
jugdish's Avatar
jugdish
I am currently running 89. My plan is to run a couple of tanks of each to see what affect the ethanol has on gas mileage. I will most likely stay with the 89, but I like testing stuff like this.
