Exhaust
First time looking at the site. Pretty impressed. Im looking for some suggestions for a new muffler. I just picked up a 2010 Dodge after having an 02 for the last 8 years. Flowmaster vs. Dynamax vs. Magnaflow. Just looking for a muffler not a cat back system. What do you think?
I purchased a 24" Magnaflow just the muffler and had a shop weld it in. There is a mufflex out there as well, some guys have had luck with them and others have had the clamp on's rattle off. Personally I would weld it on. Go on you tube and type in magnaflow mufflers for Dodge RAM and you can hear them.
The 24" Magnaflow was perfect for me, nice rumble upon start up and then idles out with a deeper rumble then on the highway there is no drone.
You can get a muffler kit for the single or dual exhaust from Mufflex. They use Magnaflow mufflers for their exhaust kits. They have various sizes depending on how mellow/aggressive you want your exhaust to sound. The 14 Series are the loudest, and I believe the 24 is the most mellow. Obviously it's all about preference so you need to decide what's best for you. With the mellow ones you will have less of a drone in the cab, with the aggressive ones it's going to sound very nice but you're going to hear a bit of a drone inside.
http://www.mufflex-performance.com/brochure.html
i have the mufflex muffler delete kit....its quite at idle and loud when it hits over 2500 rpm. but im a youngin an like noise lol but im with those guys if ur wanting only a muffler go with mufflex its a straight bolt on, mine came with the hangers already welded into place,pipes already welded into place and u dont have to get the no muffler setup i think they have a "quite" "medium" loud".....etc..... then the all out no muffler setup
Trending Topics
So on the 24" how does it compare to stock sound and also do you notice any MPG increase?
Sorry for the long delay in the response! Been on vaca and work has been non stop! But haven't noticed any MPG increase. It has a nicer rumble than the stock for sure, decent rumble on start up, quiets out when the RPM's drop below 1000.... I'm happy.
