radiator fan on too much?
Old Apr 28, 2010 | 06:46 PM
crod's Avatar
crod
Default radiator fan on too much?
hey guys, its only high 60's temp lately here in MI. i swear my rad fan is on A LOT! wife just pulled in to the drive way and its on. is it supposed to be like that?
Old Apr 28, 2010 | 07:39 PM
SubRammer's Avatar
SubRammer
These trucks don't have electric fans so as long as your engine is running the fan is running.
Old Apr 28, 2010 | 09:03 PM
sking's Avatar
sking
UMMMM Mine has a electric fan.
Old Apr 28, 2010 | 09:05 PM
crod's Avatar
crod
yeah, mine too. lol. its mounted directly to the radiator(behind it i should say)
Old Apr 28, 2010 | 09:34 PM
chambers's Avatar
chambers
That fan is for the a/c compressor, on the 3rd gen's there was a separate smaller radiator that had an e-fan mounted to it and then the clutch fan for the main radiator. I'm pretty sure you have a clutch fan and then the e-fan for the a/c compressor as well, so if you had the a/c on or were on defrost it would be on.
Old Apr 28, 2010 | 10:03 PM
crod's Avatar
crod
oh, that might make sense. i have to look into that. cause the old lady just said she did have the air on , so ill keep a closer eye on it..
Old Apr 28, 2010 | 11:00 PM
sking's Avatar
sking
The electric fan works under slow driving or idle conditions. If the trans gets hot it kicks on, if the coolant gets hot while at a light or in park it will kick on. It's thermostatically controlled.
Old Apr 29, 2010 | 08:53 AM
Brummo's Avatar
Brummo
yup....
