Old Aug 17, 2015, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problem Guides
Print Wikipost
Any benefit to using 91 Octane as opposed to 87 on Hemi
Old May 1, 2010 | 09:51 PM
cyclone429's Avatar
cyclone429
Every hemi made is not created equal, all engines are with in chryslers specs, but no where close to being tunned for the best performance and mileage.
Run 91 octane on a cool night, or tow a heavy load during the day and hands down 91 octane will net you a increase in mileage and h/p, over 87 octane in identical conditions..
87 octane is buying you trouble over the life of your engine, ya it burns real nice with carbon build up and fouling up the throtle body.
I run 89 for point a to b, towing or highway, I run 91.
Over the life of the engine, you will save with 91 octane ( facter in cost's of flue injector cleaning with 87 and your spending the same as running 91 )
as for the extra cost, on a 35 gallon tank 91 gives me the performance, but I don't pay it unless I tow, or a long distance drive.
Old May 2, 2010 | 11:33 PM
randomdef's Avatar
randomdef
worst post ever.
Old May 3, 2010 | 09:41 AM
TI 3VOM's Avatar
TI 3VOM
I'd say yours deffinately takes the cake there man.....
Originally Posted by randomdef
worst post ever.
Old May 3, 2010 | 11:57 AM
oldpianos's Avatar
oldpianos
Since 93 is always 20 cents more than 87, I buy the good stuff when gas gets expensive. If reg was $1.00 per gallon, then 93 would cost 20% premium. When gas is $3.00 per gallon, it's only like a 7% premium! What a deal!
Old May 3, 2010 | 12:17 PM
Zigggy's Avatar
Zigggy
I personally run 89- I figure they must recommend it for a reason, and I plan on having the truck for a long time so why not?
Old May 3, 2010 | 09:12 PM
Pedro Dog's Avatar
Pedro Dog
Default Run higher octane when temp is hot and towing
I run the 87 most of the time. The ECM monitors the engine and protects it so that 87 will work. But if you are towing and it is hot, run the 89 - it will help control the early detonation (pinging)
Old May 3, 2010 | 09:14 PM
kddsRam's Avatar
kddsRam
390 hp rating with the recommended fuel, 89 octane. Run 87 and it just pulls a bit of timing back and you loose a some performance, probably not enough to notice though but you would see it on a dyno pull.
Old May 3, 2010 | 09:37 PM
randomdef's Avatar
randomdef
second worst post ever
Old May 4, 2010 | 10:00 PM
SubRammer's Avatar
SubRammer
In short, you run 89 you get the advertised 390hp. You run 87, the computer retards timing and you get less HP. As for carbon build up, fouling, etc there is no correlation to the octane rating. Run whichever you heart desires.
P.S. - Running anything greater than 89 octane does not improve performance with a factory tune on this truck, or any engine specifically tuned for a lower octane fuel. (aka You are wasting money)
Old May 5, 2010 | 09:38 AM
BigBlueEdge's Avatar
BigBlueEdge
SubRammer summed it up nice and clearly.
Rob
