Old Aug 14, 2015, 07:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Diagnostic Guide
Print Wikipost
Dodge Ram 1500 Sport 3.21 Gear Ratio Question
Old May 24, 2010 | 02:16 AM
Hemi's Deer's Avatar
Hemi's Deer
I have a 08 ram 4x4 hemi automati with 3.55 axle. On highway i average 20 MPG but as soon as i get my Travel trailer on, he fall's to 12 MPG no matter wind or not. Friends of mine as 3.92 and he average 15 MPG loaded. It's simply the mds that is kicking off. Same thing for me, 87 octane is better while loaded but 89 is much better unloaded on highway. But in your case, don't worry, hemi power under the hood means way enough power to haul.
Old Oct 13, 2010 | 11:38 AM
Bearhog's Avatar
Bearhog
Sorry for being late to the party on this tread but I just had a recent experence that might add some useful perspective. I have a '09 Crew Hemi with the 3.21 gears. I pull a 5,000lb travel trailer (fully loaded weight) with little problem except for downshifting on grades which puts the RPM in the 3K range.
I'm considering changing out for the 3.92 for one specific reason, REVERSE! We camp a lot in the mountains and need to back into sites that could be on an incline. This past weekend I almost burned out my trans backing up a slight to moderate incline. The trans temp was almost at the top end of the gauge and the truck wouldnt move unless I rev'ed the hell out of it. Had to do it because I was blocking traffic. So i'm hoping the lower rearend will make up for the higher gearing in reverse.
Hope this helps
Old Oct 13, 2010 | 02:22 PM
HEMI_ROM's Avatar
HEMI_ROM
Hope this helps
One advantage to a 4x4 just put it in 4low, thats what I do backing my TT up into my back yard.
Old Oct 14, 2010 | 02:28 PM
Bearhog's Avatar
Bearhog
Well, the gear change-out is not going to happen soon. the dealer est. is $1,864 parts and labor.
Old Oct 14, 2010 | 04:47 PM
706jim's Avatar
706jim
That seems like a lot for just one differential.
Old Oct 15, 2010 | 06:38 AM
BULLRAM's Avatar
BULLRAM
Bearhog, if you are really set on change out, you can get the WHOLE rear end assembly, and put it in your self cheaper than that, have it installed in a few hours
http://www.wholesalemopar.com/parts_catalog.html
1337.05 for a complete POSI 4:10 rear end and that was just one place I checked
Old Oct 15, 2010 | 07:25 AM
Bearhog's Avatar
Bearhog
Thanks for the head's up! I checked the website and found exactly the part and price you referenced. I also found it very interesting that the other higher ratio axles were priced higher with the 3.92 being the highest at $2,184.
How do you like your CST lift btw?
Thanks again for your help.
Old Oct 15, 2010 | 08:08 AM
HemiRAMV8's Avatar
HemiRAMV8
One more late reply...
I have 3.21s in both trucks, and they tow our 20ft boat no issue, including a 250 mile trip to my parents-in-law. Tow/Haul doesn't seem to do much other than kill the MPGs really badly (single digits). I guess the boat & trailer is about 3-4K.
Old Oct 15, 2010 | 09:26 AM
BULLRAM's Avatar
BULLRAM
Bear......I really like my lift.......it makes the truck look a lot different than it did. Rides almost stock, great height
Old Oct 17, 2010 | 01:33 PM
parlay3000's Avatar
parlay3000
Originally Posted by ran jr
Are you sure it's a 3.21? I know the '09 Sports were only offered with a 3.55 or 3.92. I'd crawl under the rear and look at the tag on the alxe. But even if it's 3.21 you should be fine. You may not be able to use top gear when pulling but your third is like the fifth on the 3.92.
Where on the axle is this found. I crawled under mine and didnt see anything that I could understand...It look like a part number or something.
