Vantech racks?
Old May 31, 2010 | 08:17 AM
oldjeep's Avatar
oldjeep
Originally Posted by RamPhreak
Nice set-up. Have any pics with your yak on it yet? I need to find a system for mine with the Ram Boxes......uggg.
No pictures with the kayaks on yet.
As for your RamBox - how much space do you have between the back (hinge) of the door and the bed? The rail for this type of rack is only about 1.25" wide.
Otherwise you could just get a rooftop rack, Yakima makes one that fits. That was going to be my second choice if I couldn't find a bed mounted system that allowed me to keep my Tonneau.
Old Jun 2, 2010 | 12:14 AM
RamPhreak's Avatar
RamPhreak
No room at all. The entire top folds back.... That same company does make a couple other styles that may work however. There is one type that mounts to the inside of the bed. May look into that further.
Old Jun 2, 2010 | 07:05 AM
TurboGPZ's Avatar
TurboGPZ
Great looking setup. !
What model rack is it??
What was that special position where the BAKFLIP opened?? As far back as possible??
Any interference up front?
Was there any drilling into the truck????
Old Jun 2, 2010 | 07:10 AM
oldjeep's Avatar
oldjeep
What was that special position where the BAKFLIP opened?? As far back as possible?? Any interference up front?
It's a P3200 - Type A1 Part number 3205
http://vantech.us/pick_up/standard_b...0_standard.htm
Yes, with the rear rack as far back as possible is where the Bakflip will open. It does hit the front rack when opening the last panel, but it just means that the BakFlip rests against the front rack instead of the back window of the truck.
One thing I should mention is that I installed the tracks as far out as I could. The nuts on the underside of the bed rails are up against the inner bed wall. I did that to try to give the bakflip as much room as possible.
