Factory class 4 limits?
Old Jun 3, 2010 | 05:26 PM
RA11325's Avatar
RA11325
Default Factory class 4 limits?
I have the factory class iv hitch and I am trying to find tow/tongue limits. I found this on a web site this correct??
12,000-lb tow rating, 1,200-lb tongue weight rating with weight distributing equipment; otherwise 5,000-lb tow rating, 500-lb tongue weight rating, includes receiver plug, 2.0" opening (trucks built 11/2002 and LATER) Hitch Ball sold separately. (For use with the 1500, 2500 and 3500, excludes the SRT-10.)
82211226AB
From http://www.mopardodge.com/accessorie...m/receiver.htm
Old Jun 3, 2010 | 06:11 PM
ilandaze2's Avatar
ilandaze2
heres the chart from curt mfg where i got my class 4 hitch. (The one that bolts to the frame and not just the bumper support. Stock one is welded to the bumper support making it a class 4 if you just bolted it on its a class 3.)
Weight Carrying 10000 lb. Tongue Weight 1000 lb. Weight Distribution (WD) 12000 lb. WD Tongue Weight 1200 lb.
Old Jun 3, 2010 | 06:12 PM
72combo's Avatar
72combo
Do you have weight distributing equipment? If no then you are the second I guess. That is how I read it
Old Jun 3, 2010 | 06:38 PM
RA11325's Avatar
RA11325
I will be getting a weight system, just not sure yet.. just wanted to reallyknow what my hitch is.. could not find it on dodges site.
Old Jun 3, 2010 | 07:41 PM
andyp4x4's Avatar
andyp4x4
Default towing
I believe the 1500 is limited to 8900 lbs for towing
Old Jun 3, 2010 | 08:59 PM
dahemi's Avatar
dahemi
Go here
http://www.dodge.com/en/2010/ram_150...owing_payload/
Click on
Need towing specifications? Download the Dodge Body Builder's Guide (146 KB, PDF).
Follow your truck options to the correct amount.
Old Jun 4, 2010 | 09:34 AM
RA11325's Avatar
RA11325
1,045 pounds. I even have this printed but must have over looked it. Its on the bottome of the pages..
Thanks
