recharging air cond.
Old Jun 25, 2010 | 08:16 AM
awful knawful's Avatar
awful knawful
Default recharging air cond.
I finally have my truck on the road! The last piece of the puzzle is to fill the air conditioning system with gas. Can anyone tell me the type of gas and amount (lbs) the system holds. There should be a sticker under the hood some where with the info. My stickers are all gone.
Thanks
Shawn
Old Jun 25, 2010 | 08:32 AM
72combo's Avatar
72combo
I would take it to a dealer or and a/c shop its under 100 bucks to fill it properly, since yours has been emptied I think you will need oil to and whatever else they put in there these days. and they can pressure test and make sure you are good for years to come. Really it's worth it. You have done so much yourself and saved so much. I would give this one to the pro's. Give the VIN to a dealer I bet they can come up with the stickers you need.
Old Jun 25, 2010 | 09:33 AM
BULLRAM's Avatar
BULLRAM
I f you are going to do it yourself..........
A/C SYSTEM
Item Description Notes
A/C Compressor Denso 10SRE15 (3.7L/4.7L engines) ND-8 PAG oil
Denso 10SRE18 (5.7L engine)
Freeze-up Control Evaporator Temperature Sensor HVAC housing mounted
High psi Control A/C pressure transducer A/C discharge line mounted
R-134a Refrigerant Charge Capacity All models - 0.728 kg (1.604 lbs.) Also see A/C Underhood Specification Label located in the engine compartment
A/C Clutch Field Coil Draw 3.2 - 3.3 amps @ 12V ± 0.5V @ 21° C (70° F)
A/C Clutch Coil Resistance 3.6 ± 0.2 ohms When measured across coil lead connector
A/C Clutch Air Gap 0.35 - 0.60 mm (0.014 - 0.024 in.)
REFRIGERANT OIL CAPACITIES
Component Name ml. oz.
Total A/C System Fill 180 6
A/C Condenser 30 1
A/C Evaporator 60 2
A/C Compressor Drain and measure the oil from the old compressor. See Compressor Oil Drain Procedure.
Old Jun 25, 2010 | 12:18 PM
awful knawful
I'm not going to do it myself. I have a friend who does this as a side job. He knows what he's doing just needed the capacities.
Thanks
Shawn
Old Jun 25, 2010 | 12:42 PM
John Valdes's Avatar
John Valdes
Thanks
Shawn
Then he does not know what he's doing. If he has the equipment he does not need to know the capacities.
