Catch Can ?
Old Jul 7, 2010 | 09:44 PM
1RamRunner's Avatar
1RamRunner
Default Catch Can ?
Will installing a Catch can affect my warranty and/or vehicle inspection?
Thanks,
Jim
Old Jul 7, 2010 | 10:38 PM
JC1390's Avatar
JC1390
why would you bother?? and no it shouldnt affect either unless your dealer is a douche.
Old Aug 6, 2010 | 01:45 PM
rking300's Avatar
rking300
Ordered my catch can from Moe's 7/27 of last week and still no status on the shipping of the item. Emailed them a couple days ago and have tried calling them 4 times but keep getting voicemail thats completely full.....doesnt look good so far.
Old Aug 6, 2010 | 01:46 PM
JB007Rules's Avatar
JB007Rules
Pardon my ignorance but what is a catch can?
Old Aug 6, 2010 | 02:12 PM
rking300's Avatar
rking300
It catches the oil that would normally be feed back into your throttle body and engine. Hemis are design to send a tiny bit of oil back into your engine and can lower your octane and dirty your TB in the end hurting performance. This you install before you PCV and it "catches" the oil. You just dump it out everytime you change your oil. It jsut bolts on.
Old Aug 6, 2010 | 03:38 PM
caca's Avatar
caca
Pardon my ignorance 2, BUT WHATS THE PCV ?..
Old Aug 6, 2010 | 03:45 PM
rking300's Avatar
rking300
"The Positive Crankcase Ventilation valve, or PCV valve, is a one-way valve that assists with the continual evacuation of gases"
Old Aug 9, 2010 | 07:01 AM
rjc799's Avatar
rjc799
It is designed to do this? That just doesn't make sense.
Old Aug 9, 2010 | 07:49 AM
rking300's Avatar
rking300
Yes its designed to do this.
Old Aug 9, 2010 | 08:43 AM
oldjeep's Avatar
oldjeep
Any valve cover pcv system will spit a little oil through the pcv valve - the rockers toss it up. Some spit more than others. It's not really an issue unless you're puking a ton of oil through. I lose less than 1/4 of a quart in between oil changes, so I have a hard time beliving that any significan oil is going out the PCV.
When you guys get one of these installed, report back on how much oil you are seeing.
