Vibration/rubbing feeling in gas pedal and steering wheel
Old Jul 24, 2010 | 01:21 AM
  #21
awful knawful's Avatar
awful knawful
Originally Posted by milestone
my truck was shaking like crazy at highway speeds, the faster I went the worse it got.... turns out the problem was mud in the wheels throwing it out of balance, the big wide wheels on these trucks are perfect spots for mud to stick and it took a lot of effort to clean them out at the car wash, I went through three cycles with the wand sprayer to blow them out completely
after cleaning them right out the truck is now smooth as silk even at high speeds!
I was thinking it was broken suspension or something it was so bad, cleaned out all the dried mud and voila, perfect again
this is not the same thing we are talking about.
Old Jul 24, 2010 | 08:00 AM
  #22
Brummo's Avatar
Brummo
Mine has slight vibration depending on the road surface, usually when I feel it. I can live with it....Doesn't happen all the time, and the truck is not a daily driver.
Old Jul 24, 2010 | 09:30 AM
  #23
1RamRunner's Avatar
1RamRunner
I have another issue that is related to the steering wheel.When I'm turning the wheel either way I can sometimes here it "rubbing" on either the column or part of it. I only notice it at slow speeds like when I'm parking. I plan on bringing it up to the dealer, along with the misalignment of my Ram Box lids, when I get my 1st oil change.
Jim
Old Aug 1, 2010 | 03:29 AM
  #24
gasguy's Avatar
gasguy
Originally Posted by FirstRam10
I've had my 2010 Ram SLT Quad Cab (Sport) for approximately 3 weeks now and just started to noticed a vibration or rubbing feeling in the gas pedal and the steering wheel. I feel the vibration all the time while driving and its very annoying. I love the truck, but hate the vibration. This is my first Dodge, after owning Fords for many years, and maybe my last......
I'm bringing it to the dealer on Monday. Hope they can fix it.
Torque Converter lockup @ highways speeds will feel and sound exactly how you are describing it...takes a bit to get used to it, then you forget all about it. Check the 3rd gen forum, some might agree or offer more insight, good luck
Old Aug 1, 2010 | 12:48 PM
  #25
RAMULAK's Avatar
RAMULAK
No happening at highway speeds for me. It starts at around 30-35 and is worse at around 40mph. It happens in neutral going down hills, around corners, and around corners in neutral. Not harmonics as harmonics will usually only show at certain speeds or RPM. If you get a harmonic at 30mph you will also get it at 60mph and 120mph. I get this rubbing through a range of different RPMs, speed, weather etc. Drive line related. As mentioned could be drive shaft vibration, universals, front end joints.....Who knows.
Old Sep 5, 2010 | 10:33 PM
  #26
samhern's Avatar
samhern
Default same issue fellas
2009 mega cab 2500 with a hemi 4x4 white...07 6.7 diesel went back....2nd dodge....gas pedal vibrates at hwy speeds..been to dealer 4 times so far and they had a dodge rep check it out....yes they acknowledge its there but say its a natural and call it a drone.....kinda unsafe if u ask me....momma will not drive the truck now....it sits in thew driveway and used for trips...so far they have replaced the muffler....all engine mounts and transmission mounts...repositioned the mounts and its still there...i picked it up thurday the 2nd and drove it to a dove shoot and its worse....guys protect urselves and follow the texas lemmon law rules or rules in ur state....did this with the 07....a guy of interest if u have questions is Craig Patrick email craigpatrick@att.net he is an attorney and specializes in this stuff....never met in person just by email and phone but he helped alot.....gonna file another lemmon law dispute against them.....good luck and hope this info helps you
Old Sep 5, 2010 | 10:38 PM
  #27
samhern's Avatar
samhern
Default 2009 dodge 2500 mega cab hemi
sorry they repositioned the muffler and moved stuff around underneath. my truck does not have that mds and its doing it all the time....my opinion is over time with a continious vibration something will weaken or break causing unknown problems...FIGHT DODGE.....CALL THE CUSTOMER SERVICE AT THIER 800 NUMBER
Old Jan 15, 2011 | 01:03 PM
  #28
Mikey39's Avatar
Mikey39
I have a 2010 Dodge Ram Big Horn, I also have a serious vibration. It happens regardless of what speed I aqm traveling when the eco light comes on.... It started off not so bad, but the longer I have the truck the worse it gets.
I took it into the dealer, the service manager road with me, he felt it and said "ohh thats normal", "they all do it"... NORMAL, are you frikin serious?
When you pay 36,000 for a truck, you expect it to run properly! This is not proper!
I am now dealing with this issue at the Coorperate level. I will not settle for a truck that looks good and runs like a 82 chevette with unbalanced balled tires....
If I cannot get this problem resolved, I will file a claim utilizing the lemon law..
Old Jan 16, 2011 | 09:24 AM
  #29
samhern's Avatar
samhern
Default another one
I have a 2009 2500 MEGACAB 4x4 HEMI with 315x17x70 tko's....my truck does it at 60 mph....i have taken it back to dodge and after 4 attempts i am told its normal...its just a a droan.....my experience is that over time the vibration will cause something to brake.....so far dodge has replaced the muffler..all engine mounts...i'm scheduled for a hearing before a administrative law judge next month....dodge has offered me 4500 and a 7yr 100k mileage warranty no deductable.....my truck is non mds......to benefit from the lemmon law u must stay on top of the problem and force them to try and fix it....read ur local law and start it now.....if u need a lawyer use craig patrick. he is in dallas tx and this is what he does...i'm told the most they can offer is 10% of the msrp...if u need info call 214-354-6509
Old Jan 16, 2011 | 01:22 PM
  #30
HEMI5150's Avatar
HEMI5150
"momma wont drive the truck now"
I went thru the same issue with "my" wife too, i resolved THAT issue by telling her... "honey, i had a vibrator installed in the truck just for you",
now i cant keep her out of my truck
