Leveling kit suggestions
Old Aug 1, 2010 | 06:36 PM
puckstopper337's Avatar
puckstopper337
Default Leveling kit suggestions
Have a new 2009 Ram 1500 4 by 4 SLT Crew want to get leveling kit and tires looking for suggestions and pics... Im between a 2.5 inch level with 1inch rear blco ang 2 inch front level... Also trying to decide on bf goody AT TA KOs 33 to 35 inch on stock 17 inch rims till I can afford better rims any suggestions....
Old Aug 3, 2010 | 03:04 PM
tmot35's Avatar
tmot35
I have the Rough Country lift and level and have never liked it. I find the front sits higher than the back, I also have a squeak in the front now because the metal is rubbing on the metal mounts. I believe the new kits come with a rubber spacer but to change it now it will require another allignment.
Old Aug 3, 2010 | 05:07 PM
awful knawful's Avatar
awful knawful
I think the RC lift is a 2.5f/.75r. I put on the daystar(all ruber) 2.5f/1.5r. it's pretty level, may be a tad higher in the rear. very happy.
Old Aug 3, 2010 | 06:06 PM
oldjeep's Avatar
oldjeep
What I've found is that after 30K miles it seems to have leveled itself
Old Aug 3, 2010 | 06:21 PM
MTtruckr's Avatar
MTtruckr
I'd recommend 2.5 front and 1.5 rear. I did that and I feel anything less that 1.5 rear would have been nose high. I'm very happy with the results.
Old Aug 4, 2010 | 06:04 PM
puckstopper337
Great I think I will go with Daystar I was leaning tword that any tire suggestions how big should i go I was thinking 35s were to big maybe 33 to 34inch does anyone have pics.....
Old Aug 4, 2010 | 06:15 PM
pdavis53's Avatar
pdavis53
Well after seeing that you live in Watertown you had better make sure that they are good in the snow. I lost 4 years of my life up there back in the 90's at Ft Drum. Anyway do not get Mud tires they suck in the snow, I would look at BF Goodrich All Terrain in a 34 in tire. I am looking to do this setup. Stay with the same width as the stock tires. Big fat tires are worse in the snow so keep it narrow. The biggest thing about tires is you have to like the way they look. Go to your local tire store and look around. Most tires now a days perform similar. Get one with a mileage warrranty and one that you like and you cannot go wrong.
Old Aug 4, 2010 | 10:35 PM
jbgp1200's Avatar
jbgp1200
11k milles with the day star leveling kit no issues at all. sits almost perfectly level.
Old Aug 5, 2010 | 08:35 AM
pdavis53's Avatar
pdavis53
You say almost perfect, what ends sits lower? If it is the front then that is okay IMO.
Old Aug 5, 2010 | 09:49 AM
jbgp1200's Avatar
jbgp1200
The front is lower but im telling you when you look at the truck you cant tell its not level. at least i cant.
