Heavy Duty Rear Coils
Old Aug 5, 2010 | 10:30 PM
devile's Avatar
devile
for those with a big concern of looks with your truck, the heavy springs would be good if you have a leveling kit, that way the back won't look like it's saggin bad when towing... My only thought, now i'm curious to see how heavy duty they are, and how they affect the ride...
Old Aug 5, 2010 | 10:36 PM
Secret Agent Man's Avatar
Secret Agent Man
I have yet to ride in a HD 4th gen Ram yet, but I've never ridden in a truck with rear leafs that had a 'nice' ride. Are the HD 4th gens an exception to this?
Old Aug 6, 2010 | 10:57 AM
jayman84's Avatar
jayman84
Originally Posted by oldjeep
What are you hauling that is causing the truck to bottom? My truck rides level with about 1000lbs in the bed and 200-300lbs of tounge weight. I'm assuming your bottoming is coming from you cutting the coils shorter, which both decreased the ride height and would have taken some of the spring out of the steel since you used a torch to do it.
This is pretty standard for my truck - bed full of gear and firewood, kayaks up top, 5 people in the truck and a 3000lb boat on the back. Back of the truck still sits a tad higher than the front with that load on it.
False. try actually putting 1200 pounds in the bed of your truck and then put a picture on here of it sitting level. I have had almost 1300 pounds of seed in the back of my truck and the a$$ was dragging big time. I'm betting you dont have as much weight in the back as you think you do.
Old Aug 6, 2010 | 11:15 AM
tombogue09's Avatar
tombogue09
x2
I've had less than 1000 lbs in my bed and sags passed the level height
Old Aug 6, 2010 | 11:21 AM
oldjeep's Avatar
oldjeep
I'll have to figure out where I'm going to get a measured 1200 lbs from What do you figure a half bed full of oak weighs?
I've got 600lbs of rocksalt in the bed all winter long, and that barely moves it at all.
Old Aug 6, 2010 | 12:48 PM
09RuffRam's Avatar
09RuffRam
with my truck loaded with tools and than my quad it squats pretty low. i like when the back sits a lil higher than the front
Old Aug 7, 2010 | 04:57 PM
The Craig Machine's Avatar
The Craig Machine
Your truck is 2wd which means the front end is a lot lower than our 4X4's. Also, the 2wd has a higher payload/towing rating than the 4X4, especially the 4wd crew cabs. I'm thinking that these things MAY have something to do with it.
Old Aug 7, 2010 | 08:08 PM
rdculus's Avatar
rdculus
I dont think you're reading properly. My truck doesnt bottom out, I dont haul ANYTHING in the back of it. Nor do I want heavier coils in the rear.
I started this thread because I came across some useful information that I wanted to pass along to others.
What I did to my coils has nothing to do with this thread.
I have seen alot of fourth gens loaded down with tools, campers, dirt, gravel, atv's ect. Perhaps some of those guys may be interested in beefing up their rear suspension, obviously you're not. that's Great.
Old Aug 7, 2010 | 09:44 PM
oldjeep's Avatar
oldjeep
Ah, guess I was confused. Your other thread said you cut your coils and then found some place that you could get custom coils for $400 - I assumed that these were the same coils you were talking about in that thread.
Old Oct 6, 2010 | 02:22 PM
pdavis53's Avatar
pdavis53
Default Opinion's
Hello eveyone,
I have been thinking about this a lot and I wanted to get some opinion's about these spring's. When I first posted I did not have a leveling kit but I am now running a 2.5" Mopar kit. I was only originally planning on running a 1.5" kit, so now the rear has become more important to me. I origanally like the airbag setup for about $280(Bags and compressor) Now I would like to raise the rear a tad and decrease the sag a bit when towing. I tow a 4000lb boat in the summer and haul the occasional Uhaul size trailer(5000lbs loaded) I found a company in PA that sells HD springs for the rear that provide 1/2"-1" of lift and are supposed to decrease sag. The guy told me what I wanted to hear in that the guys that had them where very happy and the trucks did not sag anymore under load. So here is my question. I can either put a spacer and airbag system for about $400 and have a tuneable suspension and maintain factory ride or I can get the new HD springs and be done with it. What would you do?
