tire wheel combo don't fit!
Old Sep 3, 2010 | 05:56 PM
ran jr's Avatar
ran jr
Originally Posted by big4x4dodge09
negative. i go off-road and the last thing i need is some bolt breaking off and my wheel goin down the trail. using a spacer works, but if you go off-road, it puts more tention on the bolts that you put your wheel onto, more tention on less bolt. breaks....happened to my buddy
That's interesting you mention off roading because it a very common practice to use spacers on Jeeps. It allows them to run a wheel with another lug pattern or just move them away from the body to clear larger tires.
Old Sep 4, 2010 | 09:37 PM
Rizam's Avatar
Rizam
I have spacers on mine from the Last wheels, I just left them on. I off road daily for work and havent had an issue. I would think if you were off roading in a way that you could snap some lugs, many other things woud break prior.
Old Sep 4, 2010 | 11:53 PM
oldjeep's Avatar
oldjeep
Yes and no. If you are talking about plate spacers that just go on between the lugs and the wheels, then no - they are a bad idea even on a jeep. If you are talking about 1.25" or thicker spacers that bolt to the lugs and then have a second set of lugs - then yes, but only a marginally better setup and certainly not something I would use on a 6000lb truck.
Old Sep 5, 2010 | 10:34 AM
big4x4dodge09's Avatar
big4x4dodge09
it is common, but i dont recommend it. even the off-road shop i do all my stuff at recommends that.
Old Sep 5, 2010 | 11:48 AM
graverobber09's Avatar
graverobber09
The MO951 only come int 5.71 and 6.18,,,,gotta do some homework before you buy, You need atleat a 5" to clear...Sucks
Old Sep 5, 2010 | 03:13 PM
HammerZ71's Avatar
HammerZ71
I grew up around lifted trucks. My grandfather, uncle and father were mechanics by trade and had trucks with some degree of lift. Back in the day, wheel spacers were taboo and you heard horror stories about them all the time.
I even had a co-worker in the early '90s when I was a network tech who had wheel spacers on a lifted Nissan and lost a wheel on an on-ramp on I-85 in Atlanta due to a spacer failure. Personally, I'd never use them and would just buy a wheel with the right offset and backspacing.
However, I've had many a discussion with not only guys who run them and guys who have 4x4 shops who use them, but also guys who actively race lifted trucks off-road who use them and they all swear by them and claim that billet hub-centric spacers are stronger than the actual hub itself. Awful lot of 3rd Gen guys run 'em and I've not heard of anybody having an issue.
So, be your own judge...
