Superchips Torque Management Settings Question
Old Sep 9, 2010 | 12:23 PM
Swiftks's Avatar
Swiftks
Default Superchips Torque Management Settings Question
Quick question, I just got my Superships 3865, and did full update, including the Shift Schedule & Torque Management update/add-on. When I go to my TM settings, I have 2 things I can set to "user" or "superchips". The second is WOT, I remember that for sure... Can't remember the name of the first, maybe throttle torque m, sorry I'm going off of what I remember from yesterday afternoon. Anyway, do I set both setting to "user" and the change ALL the setting under BOTH to 8%? Or, do I just set the WOT setting to "user" and change those to 8% (leaving the first option, whatever the hell it was, as "superchips")??? Thanks for your help.
*Update*
The other option I was talking about is called "Part Throttle Shifts" under TM Settings. Do I need to change it to "user" setting as well and change everything under it to 8%???
Old Oct 20, 2010 | 01:11 PM
s13_marine's Avatar
s13_marine
So, you have an option to change your part throttle shifts? Can you walk me through how to get there? Because I can only change my WOT shifts.
Old Oct 20, 2010 | 03:36 PM
Swiftks's Avatar
Swiftks
I can't remember that great off hand, but I'm pretty sure you just navigate your to the Torque Management Settings Menu, set it to user, and then I believe you should have the option to change both the WOT & PTS to whatever you want. Which ever screen you can select WOT, is the same screen where I see PTS. Sorry, this is kind of vague, it's been a couple of months, anyway, I just set both / everything to 8%. I'm sure someone can correct me if my directions above are wrong.
Old Oct 20, 2010 | 04:20 PM
jaflowers's Avatar
jaflowers
I set both to "User" and then set every single gear to 8%. Took awhile the first time but now it keeps that in it's memory. Runs great on those settings for my truck.
Old Oct 20, 2010 | 06:16 PM
mel5151's Avatar
mel5151
New Member
Are Superchips Torque Management settings set to 8%? If not, anyone know?
Old Oct 20, 2010 | 06:47 PM
jaflowers's Avatar
jaflowers
The "Superchips" TM settings are not at 8%, they are at a little higher like 10+%. This means that more of the factory tourqe management system is active with their settings. It had been beat to death in the old SC thread and most thought that 8% seemed to be the really sweet spot, it also happend to work well on my truck too.
Old Oct 20, 2010 | 10:24 PM
CarGuyOhio's Avatar
CarGuyOhio
If I am not lazy I will post my shift sched this weekend, but a peak into my settings.... I am at 6% acorss the board. It is now somewhat amazing taking off "normal" and mashing it at about 20.
