Brake pedal noise
Old Sep 11, 2010 | 06:27 PM
Ross -in-Georgia's Avatar
Ross -in-Georgia
Default Brake pedal noise
For the past week whenever I press on the brake pedal I hear a squeaking noise... Have anyone noticed this if so how did you fix it?
Old Sep 11, 2010 | 11:55 PM
72combo's Avatar
72combo
Get a mouse trap.
Old Sep 12, 2010 | 01:25 AM
Sean2010's Avatar
Sean2010
I had it. bring it to the dealer they will "lube" up the pedal assembly and it will be fine
Old Sep 12, 2010 | 11:20 AM
RAMULAK's Avatar
RAMULAK
Had the same issue in my 2006 1500 and 2008 2500. I just got under there and sprayed some Silicon lube. Not WD40. Never came back. But yes the dealer will lube for you. I mean while you are there getting the shaft you might as well get the lube....
Old Sep 12, 2010 | 11:24 AM
gutty96's Avatar
gutty96
Where did you spray exactly? Mine did this a little today, and then went away. But, I would imagine it will come back.
Old Sep 12, 2010 | 11:41 AM
Secret Agent Man's Avatar
Secret Agent Man
Anywhere there is a pivot joint on the pedal assembly under the dash.
Old Sep 12, 2010 | 12:38 PM
gutty96's Avatar
gutty96
Thanks! I will wait and see if the noise comes back, then lube it up if (when) it does.
Old Sep 12, 2010 | 02:11 PM
RAMULAK's Avatar
RAMULAK
I think has been a problem with brake pedals in lots of different makes and models. In mine there is a pivot BUSHING. Should be a pivot BEARING. Just lube the pivot bushing. Like I said a silicon or a white grease spray will do the trick. Best if the truck is running and a friend/wife somebody pushes down while you spray. Keep a rag handy as you don't want to get any on the rubber part of the pedal. Makes keeping your foot on the brake a bit tricky for a while. While your down there lube the hood release and door hinges, wife, whatever else is squeeking...
Old Sep 18, 2010 | 04:08 PM
gutty96's Avatar
gutty96
My squeak came back yesterday, but a quick spray with some lube and everything is quiet again.
Hopefully it won't come back again, but at least I know what to do if it does.
