Squeaking brakes 09' Laramie
Old Sep 27, 2010 | 08:22 AM
Stonewhiteram's Avatar
Stonewhiteram
Default Squeaking brakes 09' Laramie
My truck has 40,000 mostly highway miles on it. I am running the original tires and they have plenty of tread on them. I wanted to say that to prove that this truck has had some very easy miles. Now my front brakes are squeaking under light pressure. Doesn't matter if I am going frontward or backward. Any body else experiencing this?
Old Sep 27, 2010 | 09:36 AM
Jameson's Avatar
Jameson
My truck has 600 miles and they have been squeaking since 300. I'm pissed
Old Sep 27, 2010 | 07:04 PM
CarGuyOhio's Avatar
CarGuyOhio
Put ceramc pads on it. Look at it this way....
Ceramic pads, $65 for fronts
Less dust, well dust thatis not noticable
No metal in the pad. Some of those reported rust spots on top of your paint is from your pad dust.
Lifetime warranty... So if you plan on keeping the truck for a while you will need to buy them eventually, with the warranty your second set will be free.
It really is a win win and there is little reason not to, the little being if you tow heavy items frequently.
Old Sep 28, 2010 | 01:10 AM
72combo's Avatar
72combo
40grand is more or less life expectancy of OEM brake pads no?
Old Sep 28, 2010 | 05:47 AM
05Dakotaho's Avatar
05Dakotaho
66,000 on one of my trucks. Most I've ever gotten from OEM pads.
Old Sep 28, 2010 | 07:52 AM
Stonewhiteram
I pretty sure it depends on the usage, my truck spends most of it's running time at 75 mph on the highway. Very little brake use. As opposed to someone running around town using the brakes at every intersection.
Old Sep 28, 2010 | 08:51 PM
oldjeep's Avatar
oldjeep
Seems like a good idea to take off a wheel and have a look at the pads. 40K is a good long time for brake pads. Can't go by tire wear, mine has 35K on it and the tires look new.
Old Sep 29, 2010 | 07:56 AM
Stonewhiteram
Well since I have the extended warranty that includes such things I will be taking it in to the Stealer soon.
Old Sep 29, 2010 | 08:43 PM
capsfloyd's Avatar
capsfloyd
Mine has 72000 on the brakes, I believe it is the brake dust .. when I wash it the sound goes away
