Engine spputers on my 09 ram
Old Oct 1, 2010 | 08:36 PM
ram09red's Avatar
ram09red
Default Engine spputers on my 09 ram
Has anyone experienced this problem? It does not happend all the time, however its more often now. I hit the gas from a dead stop and it sputters a little bit, then it takes off. Sometimes it does it around 30 mph then it goes away again. WHat could it be? Can some one shed some light? If i go to the dealer, and if it doesnt have a check engine light, they will tell me that everything is good.
Old Oct 1, 2010 | 11:12 PM
bry1871's Avatar
bry1871
I have the same problem but only when the motor is cold, I back out and put it into drive the the truck sputter like its going to stall. Haven't found a solution yet.
Old Oct 4, 2010 | 05:17 PM
capsfloyd's Avatar
capsfloyd
try seafoam in the tank???
Old Nov 8, 2010 | 12:59 AM
guinnessboy's Avatar
guinnessboy
not sure if the 09's had hill assist but as i understand how the option works it may be a result of that. turn off hill assist and see if you still have the problem.
