leveling kit and 35s?
Old Oct 5, 2010 | 10:23 AM
jmcintyre83's Avatar
jmcintyre83
Default leveling kit and 35s?
Any of you running leveling kits and 35s. what kit do you have and whats your current overall roof height. im trying to determine if my truck would still fit in the garage door.
Old Oct 7, 2010 | 04:11 AM
Funkyt's Avatar
Funkyt
I have a leveling kit and 295/70/18 (just shy of 34's I understand) Nitto grapplers that will rub the control arm if I have to make a tight turn. I park inside of a 6'8" garage and my antenna hits the caution sign at the entrance but the cab clears. Tons of posts in this forum on lifts and clearance etc. Just have to filter through them all.
Old Oct 7, 2010 | 05:44 AM
MiRamDriver's Avatar
MiRamDriver
I'm going to attempt to cram 325/60/20's (35.5x13x20) on my truck just before my lift and see if they will clear with only a 2" level. It'll be a while before I post results though...
Old Oct 8, 2010 | 12:25 AM
jbgp1200's Avatar
jbgp1200
I have a 2wd with a 4.5" lift and 35"s and I clear a 6'8" garage with a couple inches to spare. I think you will be fine as long as your garage opening is not 6'.
