A/C on by default!!!
Old Oct 13, 2010 | 05:19 PM
bugums1's Avatar
bugums1
Default A/C on by default!!!
Does anyone know if I can change the A/C to be off by default when I start the truck.
Everytime I start the truck, the A/C turns on. I have to push the button to turn it off. This happens even if the A/C was off before I shut the truck down.
I know it doesn't seem like a big deal, but I have remote start, and I use this to heat the truck up in the morning before I get in it. It would be better if the A/C were off during this process...
Please help if you can...
Thanks
Old Oct 13, 2010 | 05:52 PM
oldjeep's Avatar
oldjeep
Only way that should happen is if you have the temp dial all the way over to max cool - which forces the AC on
Old Oct 13, 2010 | 06:14 PM
05Dakotaho's Avatar
05Dakotaho
Old Oct 13, 2010 | 10:31 PM
CarGuyOhio's Avatar
CarGuyOhio
Yup.... Rotate your temp contol one click clockwise.
Old Oct 13, 2010 | 11:07 PM
bugums1's Avatar
bugums1
Ahh....
Thanks a bunch. I didn't think about that. I have the dual temperature control, so there is no **** to turn, but I bet I have it set all the way down.
Thanks for the help...
Old Oct 14, 2010 | 03:13 AM
kxwhite's Avatar
kxwhite
its set to come on automatically to humidify the air, and it will turn on once in while if you haven't used it in a while (ie in the cold winter months) to help lubricate the compressor.
Old Oct 14, 2010 | 08:29 AM
chris1683's Avatar
chris1683
Check your EVIC and make sure that you don't have the Comfort Assist system on. This will control your climate when using a remote start.
Old Oct 14, 2010 | 08:46 AM
1970Duster440's Avatar
1970Duster440
Mine doesn't do this. Went out and tried it to make sure before I posted. ??????
Old Oct 14, 2010 | 12:53 PM
706jim's Avatar
706jim
Couldn't you just turn the A/C dial to off?
