Moving to a smaller rim ----> Issues?
Old Oct 19, 2010 | 12:03 PM
GMONEY126's Avatar
GMONEY126
Default Moving to a smaller rim ----> Issues?
I have a 2009 Dodge Ram Sport CC 4x4. The current wheel setup is the stock 20" chrome clad rims and tires.
I'm interested in a winter wheel/tire package and was wondering if there are any problems in going down to a smaller rim 17" or 18"?
Any help is greatly appreciated.
Old Oct 19, 2010 | 12:08 PM
HammerZ71's Avatar
HammerZ71
Nope you'll have no problem as long as you go with 17" or above. I personally don't like a 20" wheel on a 4x4 myself, unless it's strictly a pavement queen, then you can get by with little side walls.
With an aluminum after-market wheel you'll save a good bit of weight, not to mention you'll save a bundle of $$ purchasing a 17" or 18" tire...
Old Oct 19, 2010 | 12:13 PM
BULLRAM's Avatar
BULLRAM
your speedo will not read correct unless you stay with the same overall height you started with
GMONEY126's Avatar
GMONEY126
Thanks for the help - so no Brake Caliper issues size wise...?
I would have thought with a bigger rim, the brakes and calipers would have been larger.
Old Oct 19, 2010 | 12:17 PM
HammerZ71's Avatar
HammerZ71
I believe the calipers are the same as 3rd Gens, 17" is the minimum wheel to clear...
Old Oct 19, 2010 | 12:39 PM
Laramie1997's Avatar
Laramie1997
Flip a $100 bill to you service department, or buy a tuner and you can get aroudn that.
Old Oct 19, 2010 | 05:57 PM
HammerZ71's Avatar
HammerZ71
This is true, although some dealers will do it for less and I've even seen some do it for free (if the vehicle was originally purchased there).
There does seem to be a misunderstanding I've noticed with some guys though. A 33" tire has a 33" diameter (roughly) whether it's mounted on a 15", 17" or 20", etc. wheel.
You're speedo will only be noticeably off if you change TIRE diameter...
Old Oct 19, 2010 | 06:48 PM
oldjeep's Avatar
oldjeep
The stock tires on the stock 17's are 31.6"
Old Oct 19, 2010 | 07:00 PM
ridem high's Avatar
ridem high
I would suggest 18" wheels.17" is very,very,close to the rotor and caliper.I have 18" wheels on my truck.
Old Oct 19, 2010 | 07:06 PM
oldjeep's Avatar
oldjeep
17" is one of the 2 stock sizes, they fit fine.
