Help and opinions with rims
Old Oct 23, 2010 | 02:38 PM
countryboy502ss's Avatar
countryboy502ss
Default Help and opinions with rims
ok, I finally put the level kit, now time for rims. I am going with 35x12.5 r17. the rims I was going to go with are the eagle 050 the specs are
0502-885517x8Super Finish Black5 on 5/5.5+20 mm5.1873274-062100 lbs.26.7 lbs.
can someone tell me if this is the correct bolt pattern, and how far will they stick out.
Thanks
Old Oct 24, 2010 | 07:34 PM
ridem high's Avatar
ridem high
5x5.5 is the correct bolt pattern.Should stick-out about 1-1/4, 1-1/2 more than stock.The bolt pattern can also be expressed as metric also,being 5x139.7 I think it is.
