2010 Ram Alpine RER stereo system upgrade / wiring harness diagram
I am starting this post to help others trying who are trying to upgrade their factory 10 speaker Alpine RER system, but keep the factory deck.
After doing TONS of research on this horrible sounding (in my opinion :hehe
stereo system. I decided to upgrade.
I had originally tried to add just a Bazooka BTA8100 tube via the high level inputs taken from the sub (it sounded like crap) I then upgraded the speakers (Boston pro50SE's in the front and Focal 690 CV's in the rear) That mod actually made a huge difference in sound. If you only wanted to upgrade your dash/door speakers and didnt really care about bass, some nice 6x9s and 3.5 inchers it would be well worth it.
For me though...this was not enough. It still lacked bass and I couldnt use the tweeters in my component speakers unless I wanted to put them in the dash where the 3.5" speakers were. Ive read that several people have tried that and it sounded crappy and echoed off the windshield. TIME TO UPGRADE AGAIN!
Ordered a Peripheral PCH8 summing/line output converter and an Alpine PDX-5 amplifier. **I had originally planned on using the PDX's 5th channel (300w) to run two 12" subs in a custom box, but after hearing how the factory sub sounded with some nuts behind it and the 8" Bazooka, I felt it was more than enough bass (plus it doesnt really take up any space and I get to keep the floor cubby holes.)
If i had to do it over again I probably would have bought an Alpine PDX-4.150 and ran two sets of Boston Acoustics components Pro60SE's for the rear and Pro50SE's for the front in conjunction with a Bazooka BTA8250D**
Already had these installed.
3. Boston Acoustics Pro50SE 5.25" Component speakers. (front)
4. Focal 690 CV 6x9 speakers (rear)
5. Bazooka BTA8100 amplified bass tube.
I work at a salvage yard and we had a 2009 Ram crew 1500 with the Alpine RER system that came in wrecked in the front. I was lucky enough to be able to disect and check the polaritys on ALL the speakers/amp so I didnt have to tear my truck apart.
Mounting the speakers in the doors, I needed 1/2" spacers for the 6x9s in the rear and mounted the 1" tweeters in the upper door trim panel triangle in the front doors.
I left the headliner speakers and the center dash speaker stock. Took the LH and RH dash speaker leads, all four door speakers leads and sub high leads (coming OUT of the factory amp) and ran them into the PCH8.
High level (speaker wires) input of the PCH8:
channel 1 was the rear door speakers (which were the closest to full range freq that I could tell)
channel 2 was the front door speakers (low to mid freq's only)
channel 3 was the dash LH and RH (high freq)
channel 4 was the subs LH and RH (low freq)
Low level (RCA's) output of the PCH8:
channel 1 went to the PDX5 front high pass
channel 2 went to the bazooka low level inputs.
channel 3 went to the PDX5 rear high pass
channel 4 went to the PDX5 sub channel (I used this channel for the factory sub because the PCH8 has a remote level control on it which is nice for controling the bass, and the Bazooka already had its own remote level control)
Just for now I left the summing levels at 50% gain until I can get someone to help me professionaly tune it in.
Let me just tell you, it sounds incredible! Even better than I had hoped for.
There are 2 plugs that come out of the "alpine" amp (even though it says chrysler right on it) One is a 22 pin white plug and the other is a 16 pin black plug.
On the 22 pin connector
left to right / top to bottom
pin 1 large black wire with orange stripe (assumed ground for the amp)
pin 2 white with gray stripe (bus input)
pin 3 white with orange stripe (bus input)
pin 4 not used
pin 5 not used
pin 6 green with blue stripe (bus input)
pin 7 green with orange stripe (bus input)
pin 8 gray with blue stripe (bus input)
pin 9 gray with orange stripe (bus input)
pin 10 not used
pin 11 not used
pin 12 not used
pin 13 not used
pin 14 gray with light green stripe (RH dash speaker +)
pin 15 gray with dark green stripe (RH dash speaker -)
pin 16 gray with yellow stripe (LH dash speaker +)
pin 17 gray with no stripe (LH dash speaker -)
pin 18 green with brown stripe (LH headliner speaker -)
pin 19 green with blue stripe (LH headliner speaker +)
pin 20 gray with white stripe (sub -)
pin 21 green with white stripe (sub +)
pin 22 large yellow wire with red stripe (assumed power for the amp)
On the 16 pin connector
pin 1 gray with purple stripe (LH front door -)
pin 2 gray with yellow stripe (LH front door +)
pin 3 green with purple stripe (RH front door -)
pin 4 green with yellow stripe (RH front door +)
pin 5 green with brown stripe (sub +)
pin 6 gray with brown stripe (sub -)
pin 7 gray with dark green stripe (LH rear door +)
pin 8 gray with light green stripe (LH rear door -)
pin 9 green with yellow stripe (RH rear door -)
pin 10 green with gray stripe (RH rear door +)
pin 11 gray with no stripe (center dash speaker, didnt check polairty...I left it stock)
pin 12 gray with orange stripe (center dash speaker, didnt check polarity.. I left it stock)
pin 13 yellow with gray stripe (RH headliner +)
pin 14 green with no stripe (RH headliner -)
pin 15 not used
pin 16 not used
pic of the PCH8 installed behind the dash.
pic of the alpine PDX-5 amp installed under drivers seat.
pic of the factory amp (to the left of the steering column)
pic of the new wire harness.
pic of the focal 6x9 in the rear door.
stereo system. I decided to upgrade.I had originally tried to add just a Bazooka BTA8100 tube via the high level inputs taken from the sub (it sounded like crap) I then upgraded the speakers (Boston pro50SE's in the front and Focal 690 CV's in the rear) That mod actually made a huge difference in sound. If you only wanted to upgrade your dash/door speakers and didnt really care about bass, some nice 6x9s and 3.5 inchers it would be well worth it.
pin 4 not used
pin 5 not used
pin 10 not used
pin 11 not used
pin 12 not used
pin 13 not used
pin 15 not used
pin 16 not used
Looks good and great write up. I am looking at upgrading my highs but i keep procrastinating. Theres no end to car audio, i can always do better and so i end up taking apart my truck 100 times. Trying to fight the urge on this truck
Yes, you would need an adapter plate to run 6.5" or 5.25" speakers in your front door.
