Changing Oil
Old Nov 26, 2010 | 09:04 PM
Jack772's Avatar
Jack772
Default Changing Oil
For years I ave changed oil at 3000 miles. I'm thinking to go a little further before I change.
When do you guys change oil?
Thanks,
Jack
Old Nov 26, 2010 | 09:05 PM
oldjeep's Avatar
oldjeep
3-5K, manual says 6K
Old Nov 27, 2010 | 02:05 AM
sig40's Avatar
sig40
I go up to 8-10k on synthetic and mostly highway driving.
Old Nov 27, 2010 | 03:11 AM
tombogue09's Avatar
tombogue09
6k of hard driving on synthetic
Old Nov 27, 2010 | 03:19 AM
Laramie1997's Avatar
Laramie1997
Between 6K and 10K. Just depends on how hard I've been driving it, the weather, idle times, and believe it or not, when I can get a deal on oil. lol
Old Nov 27, 2010 | 10:26 AM
capsfloyd's Avatar
capsfloyd
Normally when the mess.comes on or around 5-6000
Old Nov 27, 2010 | 03:48 PM
hounddogg's Avatar
hounddogg
6k with a good quality oil and there are many good brands,
Old Nov 27, 2010 | 06:09 PM
ken99's Avatar
ken99
5,000 miles with Walmart SuperTech 5w-20 conventional, which is certified API rated SM. I beleive the API certification is more important than the brand you use.
Old Nov 27, 2010 | 06:57 PM
ridem high's Avatar
ridem high
I am religous on oil changes at 3,000 miles.Knowing todays oils are manufactured to higher standards,an SM rated oil could probably stand 5,000 OCI.Send in a UOA at 4,000 miles,and see what the specs are.If ok,try 5,000,see what the specs are.No two people drive the same,live in the same climates,well you know what i mean....A OUA would be your answer to see if you could do extended oil changes,and to what mileage is safe to meet,and not to exceed.........
Old Nov 27, 2010 | 10:17 PM
hounddogg's Avatar
hounddogg
Hemis are easy on oil.Pennzoil Platinum.Ultra,Mobil1,Kendall,Castrol,Super techs etc.SM rated oils will all go 6k plus easily.Thats why the NEW mileage required change is 8k on Hemi's.GM.Honda and others with their OLM systems are going further then that on most of their vehicles theses days.But 3k is long gone.
