Possible front shutter fix???
Old Dec 9, 2010 | 06:37 AM
zeek's Avatar
zeek
Default Possible front shutter fix???
Has anyone tried to drop their front diff an inch to try to make this whobble go away after the 2" lift was installed? I think it would split the difference in the CV's and driveshaft and take the whobble out. They do this on the larger lifts (4"-10") so why not the 2" lifts also. It would straighten out the CV's and should take the whobble out.
Just checking...wat do you guys think?
Old Dec 9, 2010 | 08:41 AM
jball's Avatar
jball
It's not easily possible, look at the driver's side forward upper mount, there is not much room to work with. Also, you'd get a lot of CV plunge if you dropped the differential 2", but not the control arms (the angles would become out of phase).
