Need a clear answer on tires...
Old Dec 10, 2010 | 09:36 AM
cecil07's Avatar
cecil07
Default Need a clear answer on tires...
I've been searching and searching and searching on here for a yes or no answer on 35x12.5r20's on stock sport rims with a 2 inch leveling kit...please only repond if you have this set up, my question is not answered by showing me your 35 with aftermarket rims...or a 4-6 inch lift... not trying to be rude... i just want a clear answer... thanks guys..(tire specs...34.8 high, 12.5 wide, these are the tires I am intrested in..stock 9" rim..)
Old Dec 10, 2010 | 05:39 PM
matt3's Avatar
matt3
You will rub the control arm with the factory backspacing.
Old Dec 10, 2010 | 07:44 PM
JoesBrotherRamMan's Avatar
JoesBrotherRamMan
I too am looking for these answers.
Old Dec 10, 2010 | 07:55 PM
reeseonfire's Avatar
reeseonfire
So you have to install a spacer?
I'm thinkin about getting the same set up level and 35"x12.5" but on 17" rims
Old Dec 10, 2010 | 11:13 PM
cecil07's Avatar
cecil07
I have heard they might rub.. but then I read that other have had them on with no problems so... anyone have this set up ...some one must have tried...
Old Dec 11, 2010 | 02:38 PM
CrawfishStu's Avatar
CrawfishStu
35x12.5x17 with 4" of backspacing run in the wheel well just a hair at ride height.
Old Dec 11, 2010 | 02:39 PM
CrawfishStu
That's with a leveling kit on it.
Old Dec 12, 2010 | 08:53 AM
cecil07's Avatar
cecil07
Talked to the guy who has the tires i want ... says he puts 35's on ram 1500's all the time with the factory rims...but it does require the spacer 6mm i think he said(1/4")...he also said they will fit without the 2" leveling kit... but it would rub on the plastic...
Old Dec 13, 2010 | 09:20 AM
MiRamDriver's Avatar
MiRamDriver
They will fit with a 1/4" spacer.
Old Dec 13, 2010 | 11:42 PM
Swiftks's Avatar
Swiftks
Ok, don't have them on the stock 20's, but I do have Wrangler DuraTrac 315/70/17's (pretty much the same thing as 35x12.5x17). These are 34.4" according to Goodyear website. I have a 2" Readylift leveling kit on the front end. Before I added my grill guard, which weighs down my front end, I still had enough room for another 1/2". Still not rubbing now, even with the extra weight on the front.
