Vibration issues with less wheel backspacing?
Old Dec 13, 2010 | 12:20 PM
CrawfishStu's Avatar
CrawfishStu
Default Vibration issues with less wheel backspacing?
Anyone having issues with vibration attributed to less wheel backspacing?
Rebalanced tires twice.
Rotated them around.
Wheel backspacing is 4.5".
I'm trying to see how much of the wobble I can attribute to mud terrains and/or poor wheel balancing.
Old Dec 13, 2010 | 12:24 PM
oldjeep's Avatar
oldjeep
Did you also have the truck aligned?
Old Dec 13, 2010 | 12:28 PM
CrawfishStu
Twice. Once when the leveling kit went on and once when the new tires went on.
Old Dec 13, 2010 | 12:30 PM
Attono's Avatar
Attono
Any lift?
Old Dec 13, 2010 | 12:37 PM
CrawfishStu
Lift/Leveling kit. Daystar. Just the coil spacers. I also run firestone airbags on the back for towing my buggy.
Old Dec 13, 2010 | 01:29 PM
CrawfishStu
Wheels are lug centric as well.
Old Dec 13, 2010 | 08:56 PM
Attono's Avatar
Attono
How's the pinion angle look? I wouldn't think a leveling kit would cause driveline vibes, but did you put the lift and new tires on at the same time?
Old Dec 14, 2010 | 01:02 PM
Hop's Avatar
Hop
That might be your problem. I remember reading somewhere about the stock wheels being hub centric.
https://dodgeforum.com/forum/4th-gen...shimmys-2.html
--Hop
Old Dec 14, 2010 | 01:14 PM
CrawfishStu
Pinion angle is fine. Lift went on and it was aligned. Tires went on and it was aligned again.
The stock wheels are definiately hub centric. Though I can't really see a reason why the studs would not locate the wheel properly. I always thought that hub centric was really just for safe load capacity.
Some rims come with cetering rings that make the rims lug centric.
Old Dec 14, 2010 | 01:40 PM
ran jr's Avatar
ran jr
Hub centric rings made a noticable improvement with my wheels. I got them off eBay for $8 shipped.
