Amsoil Tranny fluid
Old Dec 13, 2010 | 08:09 PM
fargo57's Avatar
fargo57
Default Amsoil Tranny fluid
Gonna be takin the truck for its first oil change in about a week and I was also thinkin about switchin out the trans fluid for amsoil, is it really better than the factory stuff and is it a wise choice to change it? I was told I would need 7 quarts, is this right?
Old Dec 13, 2010 | 08:18 PM
fargo57's Avatar
fargo57
I also might add, (2010 5.7L 4X2)
Old Dec 13, 2010 | 09:58 PM
oldjeep's Avatar
oldjeep
Does it meet the factory spec? And what is the factory stuff not doing that you are trying to improve on?
14.8 quarts is how much a 2wd 545RFE holds. If you just drain the pan it is 5.5 for a 2wd. You need to have a shop use a fluid replacement machine to actually change the fluid. Draining only the pan and refilling with 1/3 SnakesOil isn't a real service.
Old Dec 14, 2010 | 01:19 PM
05Dakotaho's Avatar
05Dakotaho
Shifter linkage prolly stiff. That Amsoil stuff is really slippery.
