249 deg F oil trans temp- thoughts
Old Dec 30, 2010 | 10:31 AM
dodgeran's Avatar
dodgeran
Default 249 deg F oil trans temp- thoughts
I hit 121 deg c with mine while 4 wheeling this wknd....that is 249 f.
Called 3 dealers all said no problem....if light for check eng did not come on....
What are your thoughts...service reps are not mechanics but that is what I was told???
Truck ran 112 most of way in on fields (pheasant hunt) then hit 121 once so I shut it down....on way back on my trail (2 miles across fields) it ran 105.....
Had I not had this option I would not know temp....oil does not smell burnt...and have run my 03 ram this hard before...but happen to hit vehicle info as I knew I was working the truck but did not feel it was excessive...it is a 2010 ram 5.7 l auto with 8oookm
Thanks!
Old Dec 30, 2010 | 10:39 AM
pacific nw guy's Avatar
pacific nw guy
Default ignorance is bliss....
you are right if we didn't have the option we wouldn't know and wouldn't worry! same thing with the internet. I bought this truck, got on this forum and began to think I made a bad decision because of all the complaining. 1 year later I have ZERO issues.
I feel that we have to trust the engineers who built the vehicle to know what it can do. If they consider 249 safe who am I or anyone to question them. I have a lifetime warranty on my truck and I am not going to add or delete anything as I dont think DOdge would warranty a trans problem if the saw I added a cooler. Yeah a cooler is a benefit but without it coming from the factory someone could say it caused a problem.
I am sure a lot of you will disagree but I also know that a lot of you dont really know what you are talking about.......
Old Dec 30, 2010 | 10:56 AM
05Dakotaho's Avatar
05Dakotaho
A forum search of "transmission temp" will reveal what you want to know. Bottom line: change tranny fluid more often than standard interval.
