Onboard Air System
Old Jan 5, 2011 | 10:14 PM
roberttheall's Avatar
roberttheall
Default Onboard Air System
I installed my Viair 200 psi constant duty onboard air system. It is Great!! soon to come ...,.air horns. WuuHoo!
Old Jan 6, 2011 | 10:23 AM
1954Radio's Avatar
1954Radio
Old Jan 6, 2011 | 05:24 PM
dahemi's Avatar
dahemi
Where did you mount the pump and tank? The switch control in teh cab? Outboard air connectors front and rear? Lets see pics of all of it.
Old Jan 6, 2011 | 10:28 PM
05Dakotaho's Avatar
05Dakotaho
Originally Posted by dahemi
...... Lets see pics of all of it.
What? You don't see see a 200psi set up in this picture?
Your video processor may be corrupted.
I'm certain that mine is.
Old Jan 7, 2011 | 01:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You will like them. Ive got a Viair 380C with a 3 gallon tank and two horns. They get really loud
Old Jan 8, 2011 | 12:09 AM
roberttheall
I'll try to get pics soon, I mounted the tank near the outer portion of the frame on the drivers side in front of the floor cubby hole I drilled a couple holes in that cubby hole and put my compressor there with the lines running to the tank, I have the presure guage on off switch monted in the upper glove box. I have a quick connect on each side just underneath where the fron and back door meet. I'm still working out plumbing ideas and issues. I want the system completely airtight / leak free.
