View Poll Results: Which air bags?
Air Lift 1000
72.73%
Firestone Coil Rite
27.27%
Voters: 11. You may not vote on this poll
Air Lift 1000 or Firestone air bags?
Old Jan 7, 2011 | 02:49 AM
yotaman96's Avatar
yotaman96
Default Air Lift 1000 or Firestone air bags?
I see most people are happy with either. Haven't decided which one I'm getting. Is there any pros or cons to either? Looks like the Firestone bags can be installed without removing the springs while you have to remove the springs with the Air Lift kit. That's not a big deal to me though. Also, is anyone using an on board compressor with these? Which one? I know it's not necessary, but it would be convenient so the bags could easily be aired up once loaded.
Old Jan 8, 2011 | 10:49 PM
yotaman96's Avatar
yotaman96
Wow, such an overwhelming response. Seriously, anyone else?
Old Jan 9, 2011 | 10:06 AM
HG07JKRubi's Avatar
HG07JKRubi
The Air Lift installation instructions do say the springs should be removed to install the air bags...but their demo video of the installation clearly shows they do not remove the coils to install... take a look
http://www.youtube.com/watch?v=tmcKIJo1D8g
Old Jan 9, 2011 | 09:54 PM
jamesimprl's Avatar
jamesimprl
i have the airlift bags and have no issues. my cousin got the firestone bags and already had issues with them. firestone is going to fix the problem under warranty. not sure about install difference since mine were on truck when i bought it.
Old Jan 10, 2011 | 09:10 AM
iskybantilus's Avatar
iskybantilus
i have the firestone bags and have had no issues. they squeezed into the side of the springs with the axle drooping down and it took no time at all to install. mounting the air valves in the upper license plate screws was easy and makes for a very slick installation.
Old Jan 10, 2011 | 09:33 AM
sxlk20's Avatar
sxlk20
The airlift bags have a lifetime warranty, but require spring removal for installation. The video above is not the airlift installation for our application. Firestone does not have the lifetime warranty but can be installed with the spring in place. FYI airlift has a 25 dollar rebate for bags bought in January.
Old Jan 10, 2011 | 09:40 AM
05Dakotaho's Avatar
05Dakotaho
I have an issue with one of my Firestone Coil-Rites that will not hold air. Been trying to get Firestone tech to respond for a month with NO LUCK.
Old Jan 10, 2011 | 07:42 PM
HG07JKRubi's Avatar
HG07JKRubi
OP - I think you have your answer !!!
Old Jan 10, 2011 | 08:25 PM
HammerZ71's Avatar
HammerZ71
I don't know if they are the same or not, but about five years ago Firestone had a severe problem with their bags dry rotting and losing air. I went to order a set as they were the only ones I ever heard of, but a buddy of mine who owns a small chain of tire/repair shops talked me into the Air Lift bags. They are in the middle of farm country where they have installed a bunch and had issues with the Firestones.
I've not heard of it since then though, and these are of course a different type of bag system than a 4th Gen would use. But I thought I'd throw it out there...
Old Jan 11, 2011 | 10:30 AM
pdavis53's Avatar
pdavis53
Looks like it is time to get those Airlift Bags!
