Random Problems.
Old Jan 8, 2011 | 02:47 PM
mbudden's Avatar
mbudden
Default Random Problems.
My father contacted me about problems he is having with his 09' RAM. Checked for him and it seems pretty weird... He's getting a "Service Park Assist" message on his dash. I was thinking maybe it was dirty sensors because of the snow we just got last night.
But the weird problem is, his HVAC, Wipers, ESP and Air Bag don't work. The screen shows ESP BAC. I was assuming this is a fuse issue, but I can't figure out which one it could be. Since Wipers/HVAC are on two different fuses. I was thinking maybe it has to do with like a CTM fuse or something. But it doesn't mention anything like that in the manual.
Any assistance would be great.
Old Jan 8, 2011 | 03:35 PM
oldjeep's Avatar
oldjeep
ESP BAC? or ESP BAS?
ESP BAS could indicate a lot of things, most common would ba a wheel sensor which would effect the ESP and maybe park assist.
Old Jan 8, 2011 | 03:53 PM
mbudden's Avatar
mbudden
ESP BAS. My bad. Changed out basically all the fuses except for the Mopar specific ones & the relay's that are in the fuse area. Didn't solve anything.
I doubt a bad wheel sensor would take out wipers etc. That's what I find strange...
Old Jan 8, 2011 | 03:58 PM
oldjeep's Avatar
oldjeep
Points to an issue in the TPMS. Might be worth removing the top and make sure all the cables are still connected properly.
Old Jan 8, 2011 | 04:01 PM
oldjeep's Avatar
oldjeep
Remove cover TIPM.
Remove the B+ terminal nut (green arrow) from the TIPM and remove the B+ cable.
Release the 5 tabs holding the TIPM to the battery tray, lift it out and turn upside down - There will be a bunch of cables connected to the bottom of it, they have locking mechanisms but maybe one was not locked properly and came loose.
Old Jan 8, 2011 | 05:26 PM
mbudden's Avatar
mbudden
Will check that out. While testing to see what else was out. Came to find out that the rear windows weren't working either. Wouldn't go up or down from the driver side control panel, nor the switches in the back. It's quite confusing. But thanks for that, I was trying to figure out how to lift that up, as I dropped a fuse down near there.
Old Jan 8, 2011 | 10:48 PM
bigred3297's Avatar
bigred3297
Originally Posted by oldjeep
Remove cover TIPM.
wow... impressive. Is that something you put together?
Old Jan 9, 2011 | 06:20 AM
TDTIPMO's Avatar
TDTIPMO
Is there any reason why you're not taking it to the dealer? That would be my siggestion. Let them figure it out.
Old Jan 9, 2011 | 07:03 AM
oldjeep's Avatar
oldjeep
Nope, its from the install instructions for the power tailgate lock - which gets spliced into the bottom of the power center.
Old Jan 9, 2011 | 07:04 AM
oldjeep's Avatar
oldjeep
It's a 2009, probabally out of warranty already (except for the powertrain). Basic warranty is only 36K
