Bigger Gearing
I have 3.55 gears with a 34.5 inch tire. I would like to upgrade. My brother's Tundra has 4.30 gears stock and those handle nicely. If I was to do gearing I would want them to be aggressive for city driving with the big tire, so does anyone know who makes a gear that big for our Rams of quality?
Try Googling - Genuine Gear, Motive Gear, Richmond Gear, Yukon Gear.
Lowest ratio Mopar gears for the 9.25 diff that I've found are 4.10 and unless you plan to take it to the track you will prolly be thrilled with that ratio.
I take it you went with Mopar parts? Yeah, 4.56 seems a little out of my need. I just want my stock, and a little more bite back. I have to drive out of Tow/Haul mode so it doesn't hunt for overdrive..sort of annoying..By the way, is that bad on the transmission ect to be in tow/haul mode all of the time, even up to like 60mph?
Will you be planning to switch to a larger tire later? If you plan on going larger i would get the 4.56. If not, the 4.10 would be good and would give you the feeling you are looking for.... Stock with a little extra kick
Trending Topics
Rough estimates but close enuff:
4.56 calculations
Tire height change from stock = - 8% final drive ratio
Gear ratio change 4.56 from 3.55 = +28% final drive ratio
Net change = +20% final drive ratio
Original 3.55 ratio x 120% = 4.26 effective differential drive ratio.
4.10 calculations
Gear ratio change 4.10 from 3.55 = +16% final drive ratio
Net change = + 8% final drive ratio
Original 3.55 ratio x 108% = 3.83 effective differential drive ratio.
4.56 calculations
4.10 calculations
We essentially have the same truck. However I have the 3.92's and I couldn't imagine needing more. However If I had 3.55's and I was going to pay for gears I would get the 4.10's. Why not, it not much more then the 3.92 and if you go with larger tires your already set. If you buy the stock 3.92's and have the dealer install them you can probably get it warrantied. Although I do not think this is a cincern of yours so again I say get the 4.10's with a good locker. Not sure which locker because I have never ran anythin but stock.
