Cold Weather
Old Jan 11, 2011 | 09:03 AM
Tuck479's Avatar
Tuck479
Default Cold Weather
Hello, I started my truck this morning and it was 9 degrees and my onscreen display only had 3 displays: Coolant Temp, Transmission Temp and Truck Hours. The screen it defaulted to was the Coolant Temp screen and it the temperature of my truck was fine as it gradually warmed up to normal. Usually I have my miles to empty and etc on the display but not this morning. Is this normal for cold weather?
Old Jan 11, 2011 | 09:43 AM
CarGuyOhio's Avatar
CarGuyOhio
No, are you sure you did not hit the right arrow on your wheel?
To get to that screen you hit the right arrow when next to system info. To get back you hit the left arrow, or turn everything off and back on....
Old Jan 11, 2011 | 05:14 PM
oldjeep's Avatar
oldjeep
Doesn't sound normal. Only difference I have when it is below zero is that the display is pretty well frozen/slow to react until the inside of the truck warms up - which is pretty normal for an LCD.
Old Jan 18, 2011 | 11:23 AM
Tuck479's Avatar
Tuck479
Yeah, I think that I probably just accidentally hit the arrow and didn't know it. Hasn't happened sense!
