4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The factory "limited slip" does allow some slippage. It uses a set of clutch plates (7 -10 i think) with a tension plate. The clutches wear and the tension plate loses some of its spring over time resulting in more slippage/spinning than when new.
