Why 5-bolt instead of 6?
Old Jan 15, 2011 | 07:29 PM
moosnutz's Avatar
moosnutz
Default Why 5-bolt instead of 6?
Maybe a silly question - but why do the Ram 1500s use 5-bolt axle/wheels? Everyone else uses 6 lug. Is the Ram setup less stout? 9.25" rear, right? I need maximum utility out of my next (& hopefully soon) truck purchase. Can the Ram running gear hold up to actual "truck duty".
Thanks!
Old Jan 15, 2011 | 07:45 PM
CUHEMI10's Avatar
CUHEMI10
if you need utility, why not look at 3/4 ton trucks?
Old Jan 15, 2011 | 07:46 PM
2002kasner's Avatar
2002kasner
im going to say its a cosmetic reason
Old Jan 15, 2011 | 07:49 PM
HammerZ71's Avatar
HammerZ71
I've often wondered the same thing, but I will say that I've seen a lot more failed GM hubs and axles over the years than Dodge in 1/2 ton trucks and GMs have 6 lugs...
Old Jan 15, 2011 | 09:54 PM
Pedro Dog's Avatar
Pedro Dog
So why is 6 better than 5? Maybe they should be 7 or 8 lugs! If folks were posting that they were breaking wheels or having issues with the 5 lug pattern, then I would worry about it. Maybe in the old days with steel wheels it made a difference, I doubt it does today.
Old Jan 15, 2011 | 10:04 PM
HaydenWar's Avatar
HaydenWar
I have always assumed that it was because dodge uses hub centric wheels and the others are lug centric, so they need the extra lug for strength.
Old Jan 15, 2011 | 10:55 PM
moosnutz's Avatar
moosnutz
Interesting. Never thought of that.
Old Jan 16, 2011 | 11:16 AM
706jim's Avatar
706jim
For years, Dodge cars had left handed lug nuts on the driver's rear wheel only(!)
Something to do with lugs nuts spontaneously unscrewing I suppose.
Old Jan 16, 2011 | 11:37 AM
Chris Mallett's Avatar
Chris Mallett
5 or 6, it really don't matter. There is only 3 bolts holding in your wheel bearing unit.
Old Feb 28, 2011 | 05:41 PM
SDDodge's Avatar
SDDodge
It's a really interesting point. I'm finally going to upgrade from the 2wd dakota to a new Ram. Put thought i might throw this out. My dakota has a 6 lug pattern.
