Heated mirrors
Old Feb 3, 2011 | 07:10 AM
promocar1's Avatar
promocar1
Default Heated mirrors
2009 1500, 5.7 Hemi, quad cab, power rear window, NO rear defrost. Heated mirrors (heated icon on mirror), NO button to turn them on, where is it? Called dealer, told me to look on the window switches, not there. No buttons on the climate control panel. Thanks for any help.
Old Feb 3, 2011 | 08:53 AM
Skillywee's Avatar
Skillywee
I have same setup, press the rear defrost button and mirrors will defrost.
Old Feb 3, 2011 | 11:51 AM
wmichell227's Avatar
wmichell227
Push your far right heater control ****. (it should have a picture) That's the mirror defrost.
Old Feb 18, 2011 | 04:15 PM
72combo's Avatar
72combo
Did you get it to work? I just had my drivers heated mirror and module replaced, it quit,ordered part, under warranty and working good
Old Feb 19, 2011 | 04:07 PM
promocar1's Avatar
promocar1
Still can't find the switch to turn them on, no rear defrost.
Old Feb 20, 2011 | 01:17 PM
WNDERR's Avatar
WNDERR
There is NO rear defrost with the power rear window...
Old Feb 26, 2011 | 07:56 AM
TDTIPMO's Avatar
TDTIPMO
There should be a button in the middle of your heater/ac control *****. The far left one turns on your A/C I believe and the far right one turns on your heated mirrors. If you don't have the button, then you don't have heated mirrors.
Old Jun 1, 2011 | 10:29 AM
robsleeps's Avatar
robsleeps
Are you sure the power rear mirror doesn't have defrost? I have that and the heated mirrors and I am pretty sure the back windows have defrost because they cleared up for me pretty quick with they got a little fogged over night.. Maybe it was just coincidence? It is the **** on the far right side that controls them though, like every one else said
Old Jun 10, 2011 | 01:37 AM
72combo's Avatar
72combo
The sliding rear windows do not have defrost. You may have heated mirrors still but to turn them on is the switch that controls where you want the air to blow you push it in and the heated mirrors should come on if you have them.
Old Jun 20, 2011 | 09:58 PM
Shibby927's Avatar
Shibby927
You should have three ***** for your climate controls. The left one is for the level or amount of air/heat you want, the middle one is for controlling the temps, and the right one is to switch to the different vents in the truck. The right one can also be pushed in to activate your heated mirrors. It has a rear defrost symbol on it, with a little light by it. When you push it the light turns orange. If you have the power sliding rear window you do not get rear defrost, it only activates the heated mirrors then. Hope this helps.
