2011 foglight wiring question
Old Feb 6, 2011 | 12:05 AM
ZIPPO973's Avatar
ZIPPO973
Default 2011 foglight wiring question
Hey everyone, I'm working on a 2011 Ram 1500 and am adding on the Mopar Foglights. They fit perfectly but when I try to wire it up to port 23 and port 24 slots in the green C3 26 way connector, there were already wires there. I found two other empty slots that had connector pins and put the wires there, but I don't think that is gonna work cause the fog-lights come on every time I hit the brakes. I would like to fix it before I take it to the dealer for the code work. Anyone dealt with this issue before? thanks zip
Old Feb 6, 2011 | 01:29 PM
WNDERR's Avatar
WNDERR
Have you checked to see if the wiring is already there?????
Old Feb 6, 2011 | 01:33 PM
bry1871's Avatar
bry1871
I did the same thing in my 08 Charger, ran all the wires and was installing the lights to the fuse box and found wires already in place, got to digging around where the fog lights go and found connectors on both side for the new lights. Turns out I only needed the new switch.
